Hi How does one go about porting a newly released Linux kernel such as 2.6.36 to the Mini2440? Thanks
New kernel ?
The main issue is that you have to ensure all the patches that have been applied to either the kernel at http://repo.or.cz/w/linux-2.6/mini2440.git or the kernel on the download page are then applied to 2.6.36 OR some hardware bits will just NOT work. I have not heard that 2.6.36 is up to-date with these changes. There are have been several postings recently dealing with this topic.
Ok So who updates it ? It appears as if the kernel you mention in the link is maintained by someone so thats more like copying existing stuff. What makes the kernel for the mini2440 different from the traditional kernel we would use on PCs ? Is it not possible to have a predefined set of patches to apply to each new kernel as it is released to create what we would know as a patched kernel for the mini 2440 ? I am trying to determine whether or not this is something which can be done by yourself or if it is dependent on other people whom one has no control over.
It has been a long confusing story. buserror (link mentioned) did the most useful work, but it appears those changes could or did not make their way into the main kernel tree. I don't know what the current situation is. There has been no official maintainer. Several bits of hardware would not work using kernels that do not have his mods. As I recall __init_data (?) in the machine specific file seems to be the biggest issue. Patches . . . it sounds sensible, but I am no patch expert. Your last comment generated quite of discussion as well. Search for <bob> and his views on every Tom, Dick and Harry patching kernels and floating them on the internet. Hopefully, the situation will improve with the mini6410.
I'll try to check latest vanilla kernel and post patches with missing stuff to mainline. Will see ;)
I was trying to determine if there exists a generic approach to creating a new source tree from the newly released kernels or if it has to work the other way around wherein one has to work the kernel patches into the existing kernel for the 2440. If there are many people who will benefit from a well maintained kernel, why isn't someone doing it. I'm getting the impression that it may be abandoned ?
OK Downloading vanilla 2.6.32.2 to see how different this one is that we have currently for the mini 2440 Maybe we can devise a simple method of patching any new kernel.... I doubt it, but its still a maybe :) I picked up a board on ebay so at least I'll have something to test on within the next couple of weeks
Hi davef, AndreT. If anybody interested to push mini2440 changes to mainline, could we somehow coordinate to avoid duplicate work? I can make diff what isn't in mainline and post a list what should be merged to mainstream. Or anybody already to this?
open-nandra, First off, I don't have the skills to do this. I had a go at trying to encourage someone to coordinate this, but no one seemed keen to take this on. Here is the thread I was talking about: http://www.friendlyarm.net/forum/topic/1094 As far as I am aware no one has done this since buserror late last year. And my impression is that buserror's patches never made into the mainline kernel. http://repo.or.cz/w/linux-2.6/mini2440.git Russell King and Ben Dooks are the names of two guys that seem to have a lot to do with the main arm input into the kernel and Samsumg specific stuff. http://lists.infradead.org/mailman/listinfo/linux-arm-kernel http://blog.gmane.org/gmane.linux.kernel.samsung-soc I would be real useful if you could do a diff on buserror's latest kernel, the one posted in the downloads section and the latest stable kernel (2.6.36). Then maybe if it was published and see what discussion it generates. I am not a "power-user", but would appreciate things being keep up to date. I would like to continue using the mini2440s, as I have two of them and might buy a mini6410. Good luck, Regards, Dave
@davef I got one with 64MB ram and 1GB Flash - Dont think I've seen ones which have 256MB ram? @open-dandra & davef I was thinking of doing it a little differently... the patch thing. I want to write a small utility which checks for differences between our current base (the vanilla 2.6.32.2) and the new base (the vanilla 2.6.36 or what ever other new kernel comes out) Once I have it comparing the two vanilla kernel's I want to add functionality to run through the source tree of the current mini 2440 kernel allowing us to select source changes applicable to the vanilla kernel's and apply them to the mini2440 kernel thereby upgrading the kernel to the new version. Do you think this might be a sensible approach?
AndreT seems to me reasonable. But differences could be such a big that we overlook something. Anyway wait for your results ;).
Well we have a patchset from 2.6.32 and we could apply to latest vanilla and fix possible problems and post patches mainstream. Then we will have everything in mainline and we don't need to maintain our tree and also we can use new functions. Step to 2.6.33 is possible but latest stable is 2.6.36 so we are still behind.
So the idea is to get it up to date with what ever the latest kernel is (currently 2.6.36) so that we can get it included into mainline ?
Can't believe this . . . in less than an hour or so you two seem to be managing your way to a solution. Hope the rest of the process works as smoothly. Dave
First problem.... there are some patches missing. What I did is took a vanilla 2.6.32.2, which is what I believed the current kernel we're using for the mini2440 is based on. I then applied the patches attached in an earlier post here by open-nandra and created a diff from that to the kernel source we're using at the moment. Attached is the difference (missing stuff) Obviously some of it is easily explained as config files etc but there are some other issues which will need to be addressed. open-nandra, any reason why you used 2.6.32-rc8 ?
Well master branch from git://repo.or.cz/linux-2.6/mini2440.git is 2.6.32-rc8 so I used this like reference. Do you use different branch?
Now I'm really confused. If I look at arch\arm\mach-s3c2410\include\mach\leds-gpio.h on the patched version of my vanilla 2.6.32.2 i find: #define S3C24XX_LEDF_STARTON (1<<2) /* Initialise 'on' */ If I look in the same file of the source tree we're currently using for the mini2440 its not there! There's a lot of work here.... hehehe
Well we can extract patches what we have from old kernel try to apply to latest mainline kernel tree and fix a problems. Or exist better way. This will be long way :D.
I get differences the other way around also, for example:
\arch\arm\plat-s3c24xx\Kconfig on the kernel tree we're using for the m2440
contains:
config MACH_FRIENDLY_ARM
bool
help
Common machine code for FriendlyARM boards i.e. Mini2440, etc
BUT this does not exist in my patched version of the kernel.
There are things which exist in the patches which do not exist in the current version of the mini2440 kernel source. There are things which exist in the current mini2440 kernel source that do not exist in the patches. I think if we can first fix the discrepancies between the patches and the vanilla 2.6.32.2 kernel so that we actually have a working set of patches for the 2.6.32.2 kernel that would be a good first step. We can then run through the patches from 0001 through 0011 and fix them until they can be applied to the 2.6.36 kernel. I think this will be the simplest?
I'll do 1-5 :) Attached is a list of files which do not matched. Left side is what we currently know as the mini2440 kernel source. Right side is the result of taking a vanilla 2.6.32.2 and patching it with the patches you uploaded earlier. Some files only exist in mini2440 kernel and others only exist in vanilla 2.6.32.2 kernel. I am not sure how will will handle these differences now but we need to do this and work them into the patches before we can start fixing patches to work with 2.6.36. Unless you have another idea?
Lets do it primitive. Merge or apply a patch to 2.6.32.2. Fix problems test on board. Maybe we can setup some repo.or for such a work to be synchronous.
Well no just apply patches. Now trying apply those patches for latest mainline. There are some conflicts but seems solvable. Could you please test 2.6.32.2 with applied patches? Thx.
It does not compile :) This is what I was saying in previous posts that there are issues which need to be "patched" that are not covered by the patches you have.
The patches do not turn a vanilla 2.6.32.2 into a usable source tree. I think we need to solve this before trying to apply them to 2.6.36 ?
The more i look at it, the more I am convinced that the mini2440 patches are in mainline. make menuconfig ARCH=arm set all the options, including some new ones and dont forget to set cross_compiler = 'arm-linux-' under general make zImage ARCH=arm I do not have a board yet (will have it in 2wks or so) so I cannot test.
> I don't know what the current situation is. Well, if they have finally got into the mainline that is good news. As I recall 2.6.32 stable didn't have them. Has anyone been able to compile 2.6.36 and get everything to work on the mini2440? AndreT, When you say "it does not compile", what is (are) the error message(s) that you get?
It does compile I tried to patch 2.6.36 which was already patched as it appears the support for the mini244 is already included in mainline did you try to compile the kernel as per my previous post? Mine compiles, but i dont have a board to run it on (yet)
I meant to say, my previous post implies that you can download vanilla 2.6.36 and perform the steps: make menuconfig ARCH=arm set all the options, including some new ones and dont forget to set cross_compiler = 'arm-linux-' under general make zImage ARCH=arm
Been away for two days. I understand that you have now been able to get it to compile. I have the kernel, but will have to try compiling it tomorrow night. It's almost midnight in New Zealand.
Hi guys. 2.6.36 compile for mini2440 but not all work from buserror is in mainline. Lemme check tomorrow which patches are missing and sent them.
Could be that its trying to load a driver which doesn't belong to the mini 2440. I'm swamped with work today :(
Well no I already fix that and have 2.6.37-rc1 running on my mini2440 board. There is some issue with touchscreen but have to firt post fix patches mainline.
Emailed buserror, basically asking how he would suggest support of the mini2440 flavour of the kernel could proceed. Why can't FriendlyArm publish the patches that they use to tweak the kernel? The ARM kernel guru at work said that it would be "an epic job updating 2.6.32 to 2.6.36". I guess someone needs to keep on top of the changes required release by release or things get out of control pretty fast. Good luck. Dave
Well not sure about what's the process what FriendlyARM has for kernel but lot of functionality is already in 2.6.36 kernel. I post 3 patches already and board nicely bootup and is usable. So wait till patches will be accepted and then use just vanilla kernel. Not sure if we need ported ts from openmoko because there is already a ts driver (used also for 64xx).S o patches which you could apply to your 2.6.37-rc1 trees: http://lkml.org/lkml/2010/11/8/106 http://lkml.org/lkml/2010/11/8/114 http://lkml.org/lkml/2010/11/8/121
open-nandra, Just to check my understanding: - lkml is another route to get patches into the kernel? - do Ben Dooks or Russell King have to process these patches? - could the patches be applied to 2.6.36? I imagine you are notified when these changes are actually placed in the mainstream. Then would you advise the forum of this fact? I appreciate the effort you (both) have put into sorting out the confusion. Regards, Dave
I see two of the patches are also listed on: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-November/thre... So, my first and second questions are probably irrelevant. dave
open-nandra. One last (?) request. Would you mind attaching your .config file or did you use the mini2440_defconfig that came with 2.6.37-rc1? Thanks, Dave
I see kernel has gone rc2. Got my board... need to get rid of the chinese rootfs and start toying with the kernel.
Dear all, I tried the latest 2.6.37 vanilla kernel with a make mini2440_defconfig but the sound is broken. Who has also tested this vanilla version? Working version (I think it is from buserrors git): Linux version 2.6.31 (jerry@hell) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #1 Tue Feb 15 20:13:43 CET 2011 Output on boot: Advanced Linux Sound Architecture Driver Version 1.0.20. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) With the latest vanilla at boot output: S3C24XX_UDA134X SoC Audio driver ALSA device list: No soundcards found. It also doesn't show up in /class/dev/sound Kind regards, Jerry
Sorry guys I don't check audio. My patches are stuck don't know where. I can check also also and post some patch ;). marek
Another issue is: - I am pretty darn sure that you have do a config_min2440_xxx, xxx being the touchscreen you are using, for a complete configuration of the mini2440 to take place. Maybe, this will help: http://code.google.com/p/friendlyarm/wiki/Linux_Tutorial
