Hi all !
i am new to cross-compile process. i had created toolchain from friendlyarm
by installing arm-linux-gcc(4.3.2) compiler and scratchbox2.
and i have successfully compiled Hello World program (it isn't so hard),by
typing file and output file name it gives me :
ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked
(uses shared libs), for GNU/Linux 2.6.14, not stripped
but ,when i tried to compile gtk2edit code by
./configure --target=arm-linux
in sb2(scratchbox2) it gives me error like this :
checking build system type... arm-unknown-linux-gnu
checking host system type... arm-unknown-linux-gnu
checking target system type... arm-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets ${MAKE}... yes
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for style of include used by make... GNU
checking for gcc... arm-linux-gcc
checking for C compiler default output... configure: error: C compiler
cannot create executables
check `config.log' for details.
i dont know where is the error ?
plz help me......
is there any other 'easy' way to cross-compile.....?
thanks in advance........
cross-compile gtk2edit for mini2440
The site: http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-... shows how to set up the tools which come with the mini2440.
