hi everyone,
I want to write a usb gadget driver for mini2440. can you please
point me to where i should start.
As a beginning, i want my pc to recognize that a usb device(with custom
vendor and product id) is connected when i connect a usb cable between
mini2440 and pc. Or i want to know how to enable gadget zero in mini2440.
Thanks and regards,
G. Ravi Teja
Associate Software Engineer,
IBM.
www.geekwentfreak.wordpress.com
gadget usb driver in linux
Hi, It's in the Kernel compile menu, when you compile it. there are several "modes" you can choose from. (only one at once if compiled staticaly) http://www.linux-usb.org/gadget/
hi, Thanks for help. I have tried that. I enabled Device Drivers ---> USB support ---> USB Gadget Support to be build as module. I also enabled "S3C2410 USB Device Controller", gadget zero and "Gadget Filesystem (EXPERIMENTAL)" again as modules. When i executed the following commands, root@snapper:~$ modprobe s3c2410_udc s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes root@snapper:~$ modprobe g_zero zero gadget: Gadget Zero, version: Cinco de Mayo 2008 zero gadget: zero ready sairam root@snapper:~$ I have connected a usb cable between my pc and mini2440 b-type usb port(dev port). But when i lsusb, it doesn't show up in my pc. neither in dmesg(on my pc). Is there something else i am missing. Thanks
hi, can you please tell me which kernel version you are using. i am using 2.6.32.2 from www.friendlyarm.net/downloads. This version doesn't seem to support usb gadgets. i checked mach-mini2440.c file in 2.6.32.2 and couldn't find the function s3c24xx_udc_set_platdata called anywhere. But it is called correctly in 2.6.34.7 and 2.6.36. the problem with 2.6.34 and 2.6.36 is that i couldn't successfully configure in to boot yaffs2 image as there is no config_mini2440_t35 file for them since they are linus's mainline kernels. Where can i download latest kernel configured for mini2440 with gadget usb support. Thanks.
