i'm trying to cross-compile the alsa-utils package.
the configure command i use is:
./configure --host=arm-linux --prefix=installDir \
--with-alsa-prefix=alsaLibDir \
--with-alsa-inc-prefix=alsaIncDir
I get an error: "required curses helper header not found". Before, the
configure script prints "compiler flags... -I/usr/include/ncursesw"
1. this is not the correct directory of my cross-compiled ncurses library,
which is in another directory ( somewhere in my homedir ).
Configure warns that /usr/include/ncursesw is not safe for
cross-compilation
2. when I run the same command with "sudo", then the configure prints no
erros and completes successfully
3. I've found no solution to tell the configure-script, where to find my
cross-compiled ncurses library. When I specify the CPPFLAGS variable to the
right directory, configure still uses -I /usr/include/ncursesw first.
Does anybody know how to solve this ?
Thanks !
