I'm using emdebian on a mini2440. I'm using a LAMP Server and a php
interface to change the value of 4 gpio. During boot, system runs the
following script to configure these 4 gpio like outputs. Because I need to
write on /sys/class/gpioXX/value trough a non root user (that is www-data
user), the script also changes permissions from 644 to 666.
It works fine, but, I don't know why, about 6 minutes after system booting,
the permissions of the files are automatically resetted to 644. If I login
through ssh and if I re-change the permssion to 666 they will remain
stable and all works fine.
It's incredible, I'm gonna be crazy!!!
Please, if you have any suggestion...
Thanks a lot.
Giuseppe
The script is:
echo 37 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio37/direction
chmod 666 /sys/class/gpio/gpio37/value
echo 38 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio38/direction
chmod 666 /sys/class/gpio/gpio38/value
echo 160 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio160/direction
chmod 666 /sys/class/gpio/gpio160/value
echo 161 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio161/direction
chmod 666 /sys/class/gpio/gpio161/value
troubles: permissions on sys/class/gpioXX/value file
Hi, Use EmDebian and have the same problem: ~# echo 89 > /sys/clas/gpio/export -bash: echo: write error: Device or resource is busy where is the problem ?
Mount the debugfs and take a look into the file /sys/kernel/debug/gpio to get an idea who is already using this pin.
