Hi, I Have a problem with the recording of sounds with the mini2440, if I connect an external microphone and run the command: arecord -D hw:S3C24XXUDA134X,0 -t wav -f cd --vumeter=stereo /home/test.wav all work fine. If I now want to use the microphone on board of the card as must I do? I have tried in various ways but always that outside. Thanks Luca
Microphone onboard
I know it's been sometime already but just for you to know that you may record from both input lines (onboard mic and the external one). I'm using buserror's 2.6.32 kernel with openembedded. Just check alsamixer settings. Besides mic volumes, there must be an option called "Input Mux". Default value is "differential", set it to the analog you want or "both". Then, try your command again and you'll see it works quite well. Regards, Nícolas
