Hi all,
I am successfully able to write and read data thru serial port using
this program but , when I tried with no cable ( or no input, not connecting
to any other system or device) at all the program is reading junk
characters which is output by the write function ans below is output of the
program
[root@FriendlyARM /test]# ./p1
/dev/ttySAC2: Success
valus of Fd 9 Serial Port reached
len of bytes received =1
0
1st read
1 4 0 0 0 c f0 f 0 0 0 0 9 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0
1st write
len of bytes received =11
0 c f0 f 0 0 0 0 0 0 0
2nd read
well what is the solution to avoid junk characters , ( one thing I know is
using handshake hardware wise) other solution is controlling through
software but I tried almost all different flags
but I'm not sure how to do it
thanks in advance,
armtry.
Serial Port prorgamming
Hi Bill Zimmerly,
The source is attached and the p1 is executable which I
got by command
arm-linux-gcc -o p1 source.c and u get the executable p1
Regards,
armtry.
hi all,
Please check the modified code in the attachements,
I think it is working now important thing to note is the Delay value what
we are using in the usleep function thats where the Rx delays are varied
arm-linux-gcc -o p1latest serial.c
and the result is below with a serial cable connected
[root@FriendlyARM /test]# ./p1latest
len of bytes received =32
62 79 65 35 43 56 56 46 75 46 75 46 75 67 46 45 67 45 75 46 74 56 74 57 45
67 45 67 54 67 54 67
1 4 0 0 0 c f0 f
///////////////////////xxxxxxxxxxxxxxxx//////////////////////
for no serial cable connected the result is below ( try changing the delay
value to lowest and maximum the result varies accordingly)
len of bytes received =0
1 4 0 0 0 c f0 f
for serial cable connected with loop back condition the result is below (
try changing the delay value to lowest)
1 4 0 0 0 c f0 f
len of bytes received =8
1 4 0 0 0 c f0 f
well I think my code needs to be modified , but I need some hand for that
as to where it can be tuned more.
thanks in advance,
armtry.
