I am working in porting android to mini2440.. I use cutecom to load things into board.. I ve loaded kernel image filesystem image.. once i boot got error... Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. after goin thru cutecom log found that the error is due to the line: linux command line is: "noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0" actually i didn typed anything like this into command line.. I need to change this noinitrd to initrd.. where can i change this.. I will be very thankful for ur help..
where to change the command line noinitrd root=/dev/mtdblock2
You have to setup the root file system path in U-BOOT ( if you are using it ) : plug a serial cable, launch minicom and in 3 first second after boot-up, press on a key to display U-BOOT menu
oh thanks yaar.. was using cutecom.. but after making filesystem image using mkyaffs2image-128M(previously did using mkyaffs2image). it booted well but failed to load filesystem..dunno wer the error is.. fine ill use minicom, uboot n try..
