Hi, buy a mini2440, and I could not install wince, I'm using dwn, I followed all the steps manually, but when I try to load the nk.bin nothing happens, with Linux I have no problem lying to install it, someone could help me, because I can install linux, but I can not install wince. Thanks
Hello Raad, How do you want we can help you if you don't describe precisely the steps you follow, the display you have, the nk.bin you download, the problem you encounter (what error message, etc...) ? domodom
Raad, If it is similar to the problem I just had with the trial 2440 build on the AndaHammer site: the CE boot up from NOR after the download the screen didn't display the CE load, rather dim colored lines. There are no error messages displayed. I suspect it was the screen size. I am using a 7" screen and don't think the binary was setup for that size. My own build loads and runs fine except for the FTDI serial drivers. John
I have the same problem, in my 7" screen I only see a rather dim colored lines and when I try load nk.bin using DNW, i received a message error "Could using a USB". I need your HELP please.
domodom Thanks for responding. The steps that follow are: application according DNW 1. Format the NAND flash 2. Download vivi 3. Download Nboot for WinCE 4. Download WinCE boot-logo 5. Download WinCE nk.bin The files I use are nboot_T35, Nk_T35.bin, then when I try to load the NK_T35.bin nothing happens, I tried to load the suspervivi-128M with OpenJTag loads it well for this I use an application <oflash>, but when I try to load the image it does not, on the contrary if I can load the linux image, the reference of my board is GT2440, samsung K9F2G08 - 3.5 "
Ime, Your problem sounds exactly like mine. Try the NK.bin file that is on the Forum download site. It asks you what screen you have then downloads the correct version. Or I can try to send you the latest one I built for the mini2440 7" screen. John
GT2440 is not mini2440. Are you sure the nk.bin file you use is for your board and not for the mini2440 ? domodom
