Hello! I've just set up Angstrom on my Mini2440 but I've got a problem with network. After booting I don't have 'eth0'. Ifconfig shows no 'ethx' at all but ifconfig -a shows eth1. Is it problem with U-boot? Or maybe I should change something on my system? thanks in advance best regards Tomasz
No eth0 on Angstrom
Just do: root@mini2440~# ifconfig eth1 up then do either root@mini2440~# udhcpc (busybox DHCP client, I think) or root@mini2440~# dhclient to get an IP Address. It's most likely due to a build setup issue (udev might be to blame).
I had the same issue. The problem is in the "/etc/networks/interfaces" config file. Go into the interfaces file and change. auto eth0 iface eth0 inet dhcp iface eth1 inet dhcp TO: auto eth0 iface eth0 inet dhcp auto eth1 iface eth1 inet dhcp Then reboot. Thanks for the clue Coburn64 Tav
