Hi to all. I was wonder if Mini2440 has Wear Leveling for Flash Memory. My application has a SQLite database for storing log data. This data base is a single file within the application directory. As you know log records is generated very often, and normally are readed and erased once per day. My concern is if Mini2440 hardware or WinCE6.0 OS have some kind of feature to prevent premature Flash memory damage, or how many write/erase cycles can give the memory chip. Thanks in advance, and best regards.
Mini2440 and Wear Leveling for Flash Memory.
Built into the file system. Read JFFS2 here: http://en.wikipedia.org/wiki/JFFS2 Then look for YAFFS2
Hi davef. Thanks for your response. If I understood, I have to format the NAND Flash (Supervivi's option "f") with the YAFFS2 filesystem before download the OS Image (Supervivi's option "w"), in order to ensure the NAND memory leveling? Thanks for your help.
Hi Ferite. Why not use an SD card? If I was running SQLite on the Mini I would definitely find a way to use SD and monitor to see if I needed a maintenance and card copy/swap schedule to avoid loss of data.
How do you monitor wear in a SD memory?. An external memory was not my first option because it make our product enclosure bigger, and we should add an extra cost. I'm sad to find out how few info there is in Internet for this important subject.
All flash filesystems have wear-leveling, some better then others. The standard linux images from friendly arm are already in yaffs format. so no need to do anything special. Its always a good idea to keep in mind that you are using a flash storage (for NAND or sd). like mounting /var/log, /var/tmp and others on a ram filesystem, or disable the system logger completely. Remco
Hi Remco. If I understood well, wear-leveling is not implemented by the hardware but by the software?. I wonder if the Windows CE file system implements a equivalent protection. Thanks.
I dont know anything about winCE, but it *must* implement it. if you buy a 128meg flash chip, its actually a few megs bigger. and it comes with badblocks from the factory (they guarantee that the first meg orso is badblock-free), and the number of badblocks will grow slowly over the lifetime of the chip. the 10,000 cycle limit usually stated in the datasheet of the chip, normaly means that is reached 1% badblocks at that point. Remco
Ferite, You could use a mini sd card if you are using the mini or micro 2440. It has the connector built on the board and the card only extends about 1/8 inch (2 or 3mm). John
