I'm very confused about running a program on the Mini2440. Here are the
steps I followed:
1. I created a simple ARM Linux program with arm-linux-gcc called "cloud."
2. I copied it to the Mini2440's /usr/bin directory with ftp.
3. I ran chmod on the file to make it executable.
4. I can find it with "which" but when I try to execute it...
[root@FriendlyARM /]# which cloud
/usr/bin/cloud
[root@FriendlyARM /]# cloud
-/bin/sh: cloud: not found
[root@FriendlyARM /]# ls -l /usr/bin/cloud
-rwxr-xr-x 1 root root 9852 Oct 7 03:56 /usr/bin/cloud
I don't know what to do next ... please help!
- Bill
Problems running a simple program...
try echo $PATH if /usr/bin isn't there then you need to run your program /usr/bin/cloud or add /usr/bin to $PATH variable.
If he can find it with which then it's already in PATH... try to type directly /usr/bin/cloud and see what happens. as said above, check the ftp transfer mode.
Thanks for the replies! No, the shell returns the same error whether I try ./cloud or /usr/bin/cloud ... I did notice (when Googling) that there are others who have a similar problem but nobody seems to know why. sigh. :( http://www.google.com/search?hl=en&q=Mini2440+%22-%2Fbin%2Fsh%3A%22+...=
Progress!!!
I thought that the problem might be related to libraries that the program
wants to dynamically load and now know I was correct.
I didn't have an "ldd" for arm programs, but I did use this to see what
libraries are expected:
$ strings cloud | less
...and then checked to see what libraries are missing. I found two of them
that were missing, so I ftp'd them in and now here is what I get on the
Mini2440:
Segmentation fault
...now THIS I can deal with. ;)
I guess the conclusion is, if an executable is "not found" but "which"
tells you that it is - then their are likely missing shared objects
(dynamic libraries).
Thanks again for the help guys!
You can use the following ldd script to see the required libraries:
#!/bin/sh
deplist()
echo $@
LD_TRACE_LOADED_OBJECTS=1 $@
case "$1" in
--version | --help)
echo "Erik's dependency lister"
echo "Invoke as $0 <binary>"
exit 0
echo "$0 unrecognized option"
deplist $1
esac
