All you wizards out there, When configuring the core functions, .NET3.5 can be selected, but is it actually part of the build? Or does it have to be added separately? The documentation on Microsoft's site seems to indicate that .NET 3.5 compact needs to be installed via Active sync. Any suggestions or ideas? Thanks, John
CE6.0 R3 and .NET 3.5 Compact
Hello John, It is maybe possible to install .Net 3.5 Compact Framework on a target via activesync, but if you select this component in platform builder before to generate your nk.bin file, the compact framework will be included in your nk.bin, you won't have to install the compact framework after via activesync Domodom
I tried to remove the Compact Framework from the catalog, and then install it with ActiveSync, but in the installation process ocurred an error wich tell me than the device is out of memory and other applications must be closed (without having other apps running). Finally I decided just let the item checked in catalog and .NET works flawlessly...
