Ciao, I wonder if this board can connect and manage 2 touch panels. if not,is possible to "split" the connector to make board believe that 2 panels are a single big one panel? if still not ,is possible to enter in contact with someone to speak about a customization of this board to achive 2 touch panels connection? thanks
can Mini6410 manage two touch panel ?
You can use TV output..... just for display For 2 touchpanals see the datasheet of controller (6410) i dont think its possible. only one controller.....
Hello Alko, Do you want to use the both touch panels at the same time ? I don't understand what you are trying to do... domodom
@domodom yes I would like to know if it possible to use 2 touch panels maybe you know libretto from toshiba,is a tablet with a double touch screen,i would like to use Mini6410 to make a smaller one. @Usama Masood yes i think the same but I would like to have a confirmation. it could be possible to connect the two panels through a "split" and manage them via software ,the window would be like extended on second panel by first one and so resolution. the ideal would be a second connector for touch instead of tv output,but this means a redesign of the board. I wonder if friendly-arm would consider a customization for this board. but maybe a single customer request like this is difficult to ben done.
A touch panel can be viewed as 2 two voltage dividers (one for X, on for Y), each divider is made with two resistor (whose value depends of where the touch panel is touched). Maybe you can try to connect 2 touch panels in series, it should work if you don't want to use the both touch panels at the same time. Even if it works, be carefull because the resolution of the touch panels will reduced by half. The other solution would be to develop your own board with an external touch screen digitizer like tha AD7873 for example. domodom
Hello, i saw you would like to do board mods. Does anyone know who i can contact for info in how to make a custom version of mini6410.
