Hi all, Could you please give some advice for building ARM compiler tool chain for Mini2440 from scratch, I find some in Internet but all of them are quite old. Best regards, Eugene.
Have you look at this web site :http://www.codesourcery.com/sgpp/lite/arm/portal/release1293
If you want complete toolchains, I've made some: http://mini2440.netyxia.net/viewtopic.php?f=9&t=13 Otherwise look for crosstools-ng in google.
@Fabien thanks for tutorial. but there is a problem with building the ct-ng. while it's retrieving the tarballs i have an error: [EXTRA] Retrieving 'sstrip' [ERROR] Could not retrieve 'sstrip'. i tried thousand of times and searched the internet for 'sstrip' but i couldn't find any solution. would you pleasse help me?
Sstrip is available at https://dev.openwrt.org/browser/trunk/tools/sstrip/src/sstrip.c You can also disable it (or switch to strip) since sstrip is used when space is a critical issue (there is also libc reduction in this case). To build a toolchain from scratch, you can also check buildroot and select ARM with proper flags (check FriendlyArm output arm-linux-gcc -v)
