Hi, is it possible to specify the LCD/display type as a boot parameter ( e.g. the 7", 3.5" or VGA-board ) ? I'm working with different LCD's and dont want to flash a new kernel everytime i want change the display. There is another board called Basic2440 from stkshop.com with the same S3C2440 CPU, that should be able to switch the display mode without recompiling. Unfortunately I can not find the kernel or drivers sources for this specific board. http://en.stkshop.com/Study-Dev/ARM-board-simulator/basic2440-s3c2440-ar... -> there is a line "LCD interface: two LCD interface, use 3.5 inc LCD on board or extern LCD, LCD-VGA-S-video can auto switch without recompile soft." On a Beagleboard Clone, the Devkit8000, it is possible to switch display modes too. It goes like this: http://www.embedinfo.com/english/support/FAQanswer.asp?id=245 thanks ! Daniel
Mini2440 - LCD type as a boot parameter ?
I know there was a posting here: http://billforums.station51.net/ about the different LCD u-boot environment variables (0tb, etc). I assume changing the environment parameters using u-boot would allow you to do what you want. Dave
In kernel driver you can switch vga and display with setup proper parameters in u-boot. E.g. mini2440=3tb means 3-display type, t=touchscreen,b=backlight. For vga use mini2440=2. I don't have vga board so I don't test it. Could you try? thanks, marek
thanks for your replies I am still new to linux and the mini2440, so at first i have to get uboot work. I still have the supervivi bootloader, which was preinstalled. After that, i'll try the vga board ;)
Hi, supervivi is in NOR flash. You need to load u-boot to NAND flash. Please don't overwrite your NOR flash otherwise you need to use JTAG ;). marek
Hi, yes I know, u-boot is only in NAND-flash ;) now with u-boot installed I can select the display through the bootargs-variable like mini2440=3tb or mini2440=4 etc, no problem with the vga-board too , very good ^^ There is a small utility named "fw_printenv" in the uboot source tree under tools/env. This is a program that can read or write variables in the u-boot environment from linux-userspace. I can read the environment with fw_printenv, but when i use fw_setenv it always corrupts the environment. At next reboot I get a CRC Error and the environment is set to default discarding all previous settings. This is my fw_env.config: # MTD device name Device offset Env. size Flash sector size /dev/mtd1 0x00000 0x20000 0x20000 I'm wondering that reading the environment is possible, but writing fails. The kernel log shows no flash oder filesystem related errors. Thanks for help
