Hello, I want to start my application when I boot mini2440.. I know adding to startup will do. But, I dont want user to see the tabs (Application FriendlyArm, Games, Settings) Any solution for this?
Start your application when mini2440 boots
Of course linux. (as this topic is under linux forum) One way i found is that I moved the "/root/Settings/*" to somewhere else. and then added my own tab as "/root/Settings/My_Tab". But still I see "Documents" tab there.. I also want to remove task bar... Any solution????
Oh.. Sorry for last reply... I did not moved "/root/Settings/*". that was another issue. actually I moved /opt/Qtopia/apps/* to somewhere else and added my tab to "/opt/Qtopia/apps/My_Tab" I also want to remove task bar... Any solution????
Sorry. Did not read it was under Linux forum. My question was because I just made what you need under WinCE, by setting the OS image in Kiosk mode.
