Hi everyone, i have a SFM3520-OP fingerprint and a Magnetic Card reader with SerialPort connection, i want create some dll files in mini2440 BSP to communicate with these devices, and after generate Wince6 use this dll in C# or Vb for creating programs. How can i do this?
Add Driver to BSP
As i have gone through the application note of SFM3520-OP, you don't need any driver in bsp, it simply connect with rs232 interface, and cmos level serial connector as well and simply add serial port component in C# and just issue the commands through it, pdf file is at http://www.vistas-gmbh.com/fileadmin/Downloads/Prospekte/UF_SFM3520OP_Da...
thanks william, i know these functionality of SFM3520-OP, but i want create some high level functions in C++ like CheckID(IntPtr ID) and use this functions in C#, so i want add this library to my OS, how can i add library like this to my OS? thanks a lot.
If i good understand you, you just want to include a file in your BSP. You can see the platform.bib file to add a line to include your file. This line is constructed like this : - name of the file in the target - name and path of the file on your development workstation - some letters to hide your file and/or give it some privileges. domodom
