Can anyone tell me that If there is a c# application which is developed in windows using visual studio. Can I run the same application in Win CE on micro2440 SDK
C # in win CE
Sumeet, I have C# application that I am developing for Win CE6 using Visual Studio 2005. The application runs on my Win7, XP and 2440, but ... the project is configured for a Win CE device. If you build the project as a Win32, I don't think it will run on the 2440 (I haven't tried to download one to the 2440). Win CE only supports a subset of .Net called .NET Compact 2.0, so some library functions available for use in standard Win32 (.NET 2, 3.5 and 4) are not available under CE. C# user-level applications for CE can also be developed using VS2008, but the same issues apply with the .NET libraries. I am new to the environment so I hope I have not misstated anything. John
.NET applications for PC use are targeted to the "full" .NET Framework. When you start a Smart Device Project, Visual Studio set as target .NET Compact Framework, wich is a subset of the full .NET framework. If you want to run a routine developed for PC, you have to paste the code in a Smart Device project and remove or replace the code not supported by compact. I hope that if there is a better way, some one can share it.
