Hi all, I'm developing a project using the micro 2440. I want to prevent external access from any user to my linux console, so on the supervivi boot parameters I'd changed: Linux command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 to: Linux command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=NULL The problem is that using the above configuration boa server doesn't work. I don't have any idea how to fix it, so could someone give me a tip to solve this issue? Thanks in advance.
Boa server doesn't work without console
When you say external access you speek about internet access ? Just shut down or remove ssh and telnet deamon
Thanks for your response themadmax! The 'external access' is any access through serial (COM0) or TCP (telnet, ssh). The big problem was the serial port COM0, I can't prevent user's access to it, so I set console option to NULL. The problem with boa server is solved, just set the error output to /dev/null instead of /dev/console on boa.conf file. Now it's everything ok. I disabled telnet. Where can i find this ssh daemon? regards
ssh daemon, if it is started, is dropbear (or sshd, depends on installed packages). console=NULL prevents boot messages to display. One that you are interested is in /etc/initab. Line: S:2345:respawn:/sbin/getty 115200 ttySAC0 starts login prompt on serial port, and 1:2345:respawn:/sbin/getty 38400 tty1 starts login prompt on stdin - keyboard and stdout - display. Problem is that you prevent access for yourself also. Better solution is to set good password and leave at least ssh server.
