Hello. Can you advise any good USB-JTAG connectors for 2410 board, so I can reload bootloader into the micro controller with it? Thank you.
JTAG for S3C2410A
http://www.hjtag.com/ But also look if your flash chip is supported.
My flash chip is supported, however I don't know if HJTAG supports 14 pin connections. If it is only 20 pin, then I will need an adapert which I don't have.
