Hi I have built a winCE image and trying to drive a WiFi USB module (for more information: tp-link tl-wn321g which uses Ralink rt2501 chipset). I have added the driver (rt2501usb.dll) into OS image as a MODULE (in project.bib) and added the reg settings (project.reg). When i power on the CEPC with WiFi module connected, it hangs after extraction of NK.BIN. and then no response at all. If I let winCE load and then connect the WiFi module, winCE will not recognize it. I think it happens because driver will not load at startup if device was not connected, maybe I'm wrong. I tried connect another USB device (such as bluetooth or storage) before loading winCE, but it will make winCE hang too. So I have two problems now: 1) Why any USB devices make my OS hang during load progress? 2) My main problem (WiFi doesn't work) is because of hang at startup or I have built a wrong driver? any help can give me another hope... Kind Regards;
Problem in detecting drivers
My guess is your driver is build for x86 processor. Mini2440 is using Samsung S3c2440A ARM9 processor, meaning you need to get from tp-link a driver version which is compatible with ARM9.
