Hello! I need 10 GPIO pins, but I'm not sure if every pin on Mini is safe to use. Which one I can not definitely use? I've tried to use one of GPG pins and there was problem. thanks in advance best regards Tom
GPIO - which is not safe to use?
Hi Tom I know that the ones tied to the user buttons have 10k pull ups on them - 0,5,6,7 & 11 that is connector 12. I think all of the GPIO are configured by default to be interrupts not sure thou (actually closer to a guess based on some of the mini2440 data sheets I have looked at, one is Mini2440Essentials.pdf it shows all as eint's as signal then GPIO as alt 1) http://www.andahammer.com/assets/Uploads/All2440/Firmware/Mini2440Essent... Page 7 & 8 for user buttons / Connector 12 and page 13 & 14 for connector 4 with GPIO I am interested in what you have tried, I am looking to use 5 min and likely more. Blessings Tim
Hi Tom, this is, what I found out about GPIOs. I hope, you don't mind the german words in the table. I just copy/pasted it. I rebuild the kernel and use the /sys/class/gpio interface which is very convenient. The GPIO 203 did not work on Kernel 2.6.29, which was the default on minis with 128MB flash. All GPIOs did work on kernel 2.6.32. If you use SuperVivi as bootloader, the GPGx should be low (0) during startup, ohterwise the board will boot into the bootloader. I use vboot which does not show this behaviour. Pin Bez. GPIO Bem. ExportNr Test 9 EINT0 GPF0 160 I, O: ok 10 EINT1 GPF1 161 I, O: ok 11 EINT2 GPF2 162 I, O: ok 12 EINT3 GPF3 163 I, O: ok 13 EINT4 GPF4 164 I, O: ok 14 EINT5 GPF5 165 I, O: ok 15 EINT6 GPF6 166 I, O: ok 16 EINT8 GPG0 Button1 192 Durch Button belegt, nur I 17 EINT9 GPG1 193 I, O: ok 18 EINT11 GPG3 Button2 195 Durch Button belegt, nur I 19 EINT13 GPG5 Button3 197 Durch Button belegt, nur I 20 EINT14 GPG6 Button4 198 Durch Button belegt, nur I 21 EINT15 GPG7 199 I, O: ok 22 EINT17 GPG9 201 I, O: ok 23 EINT18 GPG10 202 I, O: ok 24 EINT19 GPG11 Button5 203 Durch Button belegt, nur I 31 GPB0 32 Da ist der Beeper angeschlossen 32 GPB1 33 I, O: ok, kein Pull-up Regards Joachim
