Hi I am using a mini2440 + VGA board with WinCE 6. I am trying to connect a Keybord and a Mouse to USB both at a time but the problem is only one device works at a time. Is there a way to make both device work at the same time. Thanks With Regards Vikram
Connect multiple devices to USB
It might be the USB hub. I have seen the same thing with one USB2 hub. Have not tried any other USB2 hubs, but USB1 hub works fine. Might be wrong though... Try that same hub connected to PC with both mouse and keyboard. If i remember correctly then it doesn't work on the PC either...
Hi Errol, Thanks for the reply. The as you said the culprit was the USB hub. I tested the same USB hub with my desktop but it failed to recognize 2 devices. Soon I will buy a new USB hub and keep let you know the result. Thanks!!! Cheers Vikram
Hello Micro2440 says USB: 4x USB-A Host, 1x USB-B Device and Mini2440 says USB: 1x USB-A Host, 1x USB-B Device I have Micro2440 256 with VGA and flashed WINCE 6.0 from thaielectronics website. I am bit confused here as i am unable to connect more then 1 USB device to the board. I already tried it with 2 different USB Hubs. Do i need a driver to support more then 1 USB device I am really stuck have any one connected more then 2 devices to Mini2440. thanks!!!! regards Vikram
