Hi, I've mini2440 with 256MB. Mini2440 is connected by both serial & usb ports. I've installed the USB download driver. When I run the DNW program, it shows serial port is connected COM2: 115200bps I've set up the NOR switch and open the mini2440, DNW shows, USB connection is ok. Serial connection is ok . However, there is nothing on the screen ? What can be the problem ? Regards Gokcer
BOOTLOADER DOES NOT APPEAR
I have the same problem when use my serial cable. When I use serial cable which comes with mini2440 in package then I can successfully see output from console.
Hi Andreas, Actually I'm using the orginal serial cables from box.The only difference is actually, I'm using a usb-to-serial adaptor because my laptop do not have any serial port.. May be it is because of this..
Disconnect the cable from your mini2440 and make a short circuit between pin2 and 3.All you type should appear on your screen (in hyperterminal or putty). Regards Luc
