Install Ubuntu on min2440
srikanth 2010-09-07 12:52:55 Link
hi all,
       I want to install ubuntu on mini2440 say on SDcard , I have seen a
manual but it says set the BIOS to CDROM , I tried to change in media type
but it is giving error,
Thanks in advance,
sri.
ellion88 2010-09-07 16:35:30 Link
Hello srikanth,
humm.... Ubuntu is under x86 & 64bits for desktop & server, but not for arm
processor.
You need to recompile all paquets.
You can find the sources her : http://archive.ubuntu.com/
I think that's every simple to use debian (emdebian)
Regard's,
ellion
srikanth 2010-09-07 18:39:50 Link
hi ellion,
          I've already tried the debian lenny but I'm unable to login
http://www.friendlyarm.net/forum/topic/1598 please check this link and give
me suggestions
I tried embedian but I'm not getting apt-get update work I'm trying to find
repositories for debian lenny
thanks in advance,
sri.
ellion88 2010-09-07 23:27:08 Link
Hello sri,
Yes ... I've look your post (and I wait a response from Coburn64 for the
config kernel).
For you ...
I think that's your /etc/securretty. Have you the ttySAC0 into inittab and
securetty ?
Or, you can check directly the files with booting with param "noinitrd" in
your bootargs, and change init=/yourscript by init=/bin/bash or sh.
I have testing, and all works.
Also you have a good tutorial in this url :
http://code.google.com/p/mini2440/wiki/Emdebian
best regards,
ellion
srikanth 2010-09-08 07:17:37 Link
Hi ellion,
          Thanks for the suggestion I've earlier followed the same link and
tried but it says
INIT: Id "TO" responding too fast: disabled for 5 minutes
do u know what needs to be done.
thanks in advance,
sri.
srikanth 2010-09-08 07:59:34 Link
hi ellion88,
            I finally tried to login but it say /lib/modules failed to load
and I tried to check ifconfig command then I get this messgae /lib/modules
loading failed
and apt-get also dosent work it say fetch failed from
http://ftp.de.debian/pool
I also tried to update repositories using
apt-get update (doesnt work) and apt-ket update doesn't work
reards,
sri.
ellion88 2010-09-08 11:31:13 Link
Hello sri,
Look in your /lib/modules if you have the good kernel installed.
For exemple :
If you recompile a kernel version 2.6.32.x you need have the folder
/lib/modules/linux2.6.32.x/ in your partition SD card.
For apt-get : you can use only if you are connected.
For check if i have a good binary into my distribution, or if I have good
compiled my prog, I use 'ldd' tools.
for example : #mini2440>ldd /bin/sh
for you, you can test with ldd /pathtoapttools/apt-get
regards,
ellion
Reply
Name
eMail (not visible)
Text
Please enter the number 2749
