new root fs & toolchain available, new kernel soon
Fabien 2010-09-07 01:42:59 Link
Hey,
I have just done compiling a new toolchain for the mini2440.
you can get it here: http://mini2440.netyxia.net/viewtopic.php?f=9&t=13
and an updated root filesystem with busybox 1.17.1 and updated libs
here: http://mini2440.netyxia.net/viewtopic.php?f=9&t=7
I will get the linux 2.6.34.6 kernel patched in a few days as well.
open-nandra 2010-09-07 07:37:46 Link
Fabien why not latest stable kernel 2.6.35.3? Is there any objection to use
2.6.34? I can participate if necessary.
davef 2010-09-07 08:49:39 Link
root-eglibc.rar
   1   root-eglibc.rar: The file "root-eglibc.yaffs2" header is corrupt
   2   root-eglibc.rar: Unknown method in root-eglibc.yaffs2
   3   root-eglibc.rar: No files to extract
Haven't had this problem before.
Dave
Fabien 2010-09-07 12:06:44 Link
Thanks for the test, I will check tonight.
Maybe something went wrong while uploading...
Kernel 2.6.35.* does not work on the mini, I have tried numerous build, no
luck... (kernel panic)
So I will stick with the 2.6.34 branch for now.
Fabien 2010-09-07 12:24:31 Link
Hey dave,
I have downloaded the archive on 2 machines and it works fine.
You should try to re-download it.
davef 2010-09-07 13:26:01 Link
I'll have to do it tomorrow.  Is the Size 92,410,560 and Packed 23,075,646?
Should WinRAR be able to extract it?
Regards,
Dave
Fabien 2010-09-07 14:26:03 Link
-rw-r--r--  1 mobyfab mobyfab 23075728 2010-09-07 01:28 root-eglibc.rar
-rw-r--r--  1 mobyfab mobyfab 92410560 2010-09-07 01:22 root-eglibc.yaffs2
$ md5sum root-eglibc.*
02aa262fc5d1b12eb4b3f587f40696a1  root-eglibc.rar
5b09484eff4ff0ad30ee75f661bb89dd  root-eglibc.yaffs2
It has been compressed with winrar on windows, so it should work fine.
GaussCheng 2010-09-08 02:49:40 Link
I can't run the  arm-920t-linux-gnueabi-gcc in my Ubuntu 10.04.When I ran
it in my terminal it says :"can't execute the binary file" :-|
davef 2010-09-08 04:31:49 Link
Worked the 2nd time.
Thanks,
Dave
Fabien 2010-09-08 10:17:27 Link
@GaussCheng
Do you have a 64bits distro ?
If you have a 32bits distro it won't work.
I will try to compile a 32bits version today.
Fabien 2010-09-08 11:22:49 Link
32 bits (i486) toolchain is now available :)
Reply
Name
eMail (not visible)
Text
Please enter the number 2647
