Mac address
Max_egodom3 2010-09-06 16:13:34 Link
I'm using mini6410 with Wince 6 and I need to change mac address because in
all boards I have it is the same -> so I can't use it in the same network.
I try to change Network address in
HKEY_LOCAL_MACHINE\Comm\DM9CE1\Parms\NetworkAddress in BSP without success.
I try also to change this value directly inside wince (via regedit) without
success.
In both case value is correctly saved, but MAC address used in network
protocol (what I can see in my DCHP server) is always the same.
Someone had solved this problem?
Thanks in advance.
Max.
Max_egodom3 2010-09-13 20:26:19 Link
Hi, nobody can help me?
Max
Sergio 2010-10-08 17:33:38 Link
The MAC address is under HKEY_LOCAL_MACHINE\Comm\DM9CE1\Parms
and the keys are SoftwareMacAddress0 to SoftwareMacAddress5
bye
S
domodom 2010-10-10 20:32:31 Link
No, the MAC address of the registry is not used by the driver, the mac
address is hard coded in the source code of the ethernet driver (i don't
remember where).
If you have just a few boards, you can just modify the driver to read the
mac address in the registry (but i suspect there is a reason why this
option is no more available...)
If you have many boards, a best solution could be to store this address in
the eeprom (with such a solution, you can update your nk.bin and erase your
registry without to loose you mac address) but it represents a bigger work
Domodom
Mehmet 2011-01-14 20:25:18 Link
Domodom said mac addess is in doruce code of the ethernet driver.
But I don't found.
Is there someone finds a solution to this problem?
Thanks.
Reply
Name
eMail (not visible)
Text
Please enter the number 4706
