Debugging without ActiveSync
yopo 2010-09-06 15:15:06 Link
I'm using a Mini2440 with Windows CE 6.0 R3. I developed O.S. (with PB 6)
and some applications (with VC++ 2005). I can debug my apps with
ActiveSync, but I don't find other way to do it.
In other platform (over CE 4.2), I debug applications from eVC++ through
Ethernet. I can do the same with Remote Tools of VS 2005 and Mini2440, but
for debug apps, just with ActiveSync (no other option).
Any ideas? Thank you very much.
Leo
BBBB 2010-09-07 01:20:32 Link
Hi Leo,
Yes you can debug via ethernet but you have to include the corecon files in
your build and run cmaccept.exe and conmanclient2.exe on the device.
Check out http://msdn.microsoft.com/en-us/library/ms228708%28VS.80%29.aspx
Having a fixed IP address for the device is a good idea at least at the
start.
John Meyer 2010-09-08 22:29:40 Link
Yopo,
As Leo stated you can use the Corecon utility, however I have found that
you must still have Activesync installed on your development platform.
You need to rebuild the OS if you want the Corecon utilities to be
installed and start up automatically.
You can copy them to the ARM and run them when you need to deploy the
application and/or debug.
I have had issues with dropping the connection, but don't know if it is
related to Corecon, my OS or hardware.
John
yopo 2010-09-13 23:26:29 Link
Attachment: options.jpg (42.28 KB)
Hi guys,
sorry for delay, I just tested this today... but it didn't work for me, I
copied all files requiered, but when I push Connect to Device, it fails:
"Connection failed. Device is not ready". I attached a jpg file with device
options, and in Bootstrapper just appears ActiveSync option :(
Thank you,
Leo
yopo 2010-09-14 22:17:10 Link
It works! I'm not sure about what I did, probably some restarts, etc, but
nothing different from instructions from link... so, thank you very much!
See you,
Leo
dezso 2011-02-14 20:42:57 Link
wow
I have been struggle with Activesync for months, this is a perfect
solution, to bad did not find it sooner !
Reply
Name
eMail (not visible)
Text
Please enter the number 4455
