Boot from USB?
UsbBooter 2010-09-05 11:05:03 Link
i've got prepaired a USB-Stick with bootable Emdebian ARM.
Did anyone test or did anyone know how can i boot from USB-Sticks?
Greets,
UsbBooter
srikanth 2010-09-06 06:52:37 Link
   Firstly I think you must change the bios settings to change the boot
priority to boot from set parameters option in BIOS when started from NOR
options and U must select the parameter accordingly for USB stick or if u
are using U-boot then u must select the name of the USB parameters
accordingly like say  root=/dev/sdb or root=/dev/sda2 , I'm not sure which
one suits well becoz in other forms they have suggested mmc.... for sd card
so I'm thinking on those lines and suggesting you this.
Thanks,
sri.
Reply
Name
eMail (not visible)
Text
Please enter the number 2799
