Qt compilation error for Arora
davef 2010-09-04 12:08:28 Link
Any suggestions to sorting this error?
/usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm
-none-linux-gnueabi/bin/ld:
warning: libts-1.0.so.0, needed by /usr/local/Qt/lib/libQtGui.so, not found
(try using -rpath or -rpath-link)
warning: libz.so.1, needed by /usr/local/Qt/lib/libQtGui.so, not found (try
/usr/local/Qt/lib/libQtGui.so: undefined reference to `ts_open'
/usr/local/Qt/lib/libQtGui.so: undefined reference to `ts_config'
etc
etc
collect2: ld returned 1 exit status
libts-1.0.so.0 is in my /usr/local/tslib/lib
libz.so.1 is in my /lib
I have tried the following at the command line:
export LD_LIBRARY_PATH="/lib:/usr/local/tslib/lib"
and
export LDFLAGS="-L/lib"
export LDFLAGS="-L/usr/local/tslib/lib"
and in qmake.conf
QMAKE_LFLAGS += -Wl, -rpath-link=/lib:/usr/local/tslib/lib
with no change in behaviour.
Thank you.
Dave
Reply
Name
eMail (not visible)
Text
Please enter the number 6693
