taskbar in linux
Jaz 2010-09-02 19:52:58 Link
Hi, does anyone know how to get rid of the taskbar in linux on the
mini2440?
Thanks!
Jaz
jrh_engineering 2010-10-25 22:28:32 Link
If you want to do it from your Qt application use:
frmMyWidget->showFullScreen();
rather than
frmMyWidget->show();
in your main.cpp or whatever file you use to instantiate your widget class.
frmMyWidget will be whatever name you have assigned to your form in
designer or whatever name you have given to your subclass object name.
int main (int argc, char * argv[])
   QApplication myapp(argc, argv);
   frmMyWidget *frmMyWidget1 = new frmMyWidget;
   frmMyWidget1->showFullScreen();
Reply
Name
eMail (not visible)
Text
Please enter the number 3039
