hello all, I continue my ongoing fight to build a custom kernel with
"buildroot" I managed to install u-boot but now I have the problem that the
kernel that I created with the buildroot does not work: I get the following
message
MINI2440 # þ
U-Boot 1.3.2-mini2440 (Oct 6 2009 - 12:51:09)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: Bad block table not found for chip 0
128 MiB
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000
Image Name:
Created: 2009-11-09 19:54:25 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1643592 Bytes = 1.6 MB
Load Address: 31000000
Entry Point: 31000000
## Booting kernel from Legacy Image at 32000000 ...
Image Name:
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
I used the following configuration:
Target Architecture
[*] arm
Target Architecture Variant
[*] arm920t
Target ABI:
[*] EABI
Toolchain
[*] Enable RPC
[*] Use software floating point
[*] Enable large file (2GB) support
[*] Enable IPV6
[*] Enable toolchain locale/i18n support
[*] Use software floating point by default
[*] Build/install c++ compiler
Target filesystem options
[ ] tar
[ ] ext2
[*] jffs2
Endianess
[*] little-endian
Flash Type
(x) NAND flash with 2kB Page and 128 kB erasesize
Kernel 2.6.30.2
[*] Linux (Advance Configuration)
Kernel Binary format
[*]zImage
any ideas?
thanks for helping
ARM Kernel with Builroot
Hi martin, Linux kernel from http://www.kernel.org/ doesn't contain all necessary files for mini2440 board. As a result you'll get unusable kernel (actually you can make diff between official kernel and the one with changes but this way is a little bit unnatural). Try to compile kernel from Buserror repo, I wrote how to do this here http://www.friendlyarm.net/forum/topic/79?lang=en#612. P.S. Could you please next time before asking the question search the forum for similar topics? Thanks.
thanks for the reply, I will next time. I managed to create a new kernel, with the instructions you gave me. but something is not right, not if the problem is in the kernel, or the FileSystem. or NAND rootfs partition. I searched in forum and I have not managed to find a similar error at 100% during kernel initialization I get the following error ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time Empty flash at 0x00003f48 ends at 0x00004000 Empty flash at 0x00007ffc ends at 0x00008000 Empty flash at 0x0000bffc ends at 0x0000c000 Empty flash at 0x00013f50 ends at 0x00014000 Empty flash at 0x00017f4c ends at 0x00018000 Empty flash at 0x0001bfc4 ends at 0x0001c000 Empty flash at 0x00023f44 ends at 0x00024000 Empty flash at 0x00027fbc ends at 0x00028000 I think the problem may be in the rootfs partition because I have errors in this partition MINI2440 # nand bad Device 0 bad blocks: 07f80000 07fa0000 07fc0000 07fe0000 MINI2440 # I have recreated several times the NAND but still contains the errors in the NAND BAD nand scrub nand createbbt .......... nand erase kernel .... mmcinit ..... fatload mmc 0:1 0x32000000 uImage-micro2440.bin ..... nand write.e 0x32000000 kernel ..... NAND erase: device 0 offset 0x560000, size 0x7aa0000 Skipping bad block at 0x07f80000 Skipping bad block at 0x07fa0000 Skipping bad block at 0x07fc0000 Skipping bad block at 0x07fe0000 MINI2440 # nand info Device 0: NAND 128MiB 3,3V 8-bit, page size 2048, sector size 128 KiB MINI2440 # fatload mmc 0:1 0x32000000 mini2440.rootfs.jffs2 reading mini2440.rootfs.jffs2 24477696 bytes read MINI2440 # nand write.jffs2 0x32000000 rootfs 1758000 NAND write: device 0 offset 0x560000, size 0x1758000 Writing data at 0x1cb7800 -- 100% complete. 24477696 bytes written: OK MINI2440 # might these rulings the cause of the error during initialization? thanks again
hi all, well I managed to run the custom kernel and filesystem on jaffs also personalized with the buildroot. but as nothing can be easy :-( :-( :-( :-( I do not get to finish initializing, stays at: Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "u-boot" ftl_cs: FTL header not found. 0x000000040000-0x000000060000 : "u-boot-env" ftl_cs: FTL header not found. 0x000000060000-0x000000560000 : "kernel" ftl_cs: FTL header not found. 0x000000560000-0x000008000000 : "root" ftl_cs: FTL header not found. I've seen higher on the initialization gives the following error, anyone knows what is that? greetings ---------------------------------------------------------------- ----------------------------------------------------------------- Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000 Image Name: Created: 2009-11-11 9:01:10 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2001524 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 ## Booting kernel from Legacy Image at 32000000 ... Image Name: Created: 2009-11-11 9:01:10 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2001524 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux............................................................. ................................................................. done, booting the kernel. Linux version 2.6.31 (root@debian) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3- 72) ) #1 Wed Nov 11 03:47:02 EST 2009 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: MINI2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, (c) 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200 PID hash table entries: 256 (order: 8, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60700KB available (3508K code, 417K data, 128K init, 0K highmem) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing pending status 02000000 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 MINI2440: Option string mini2440=0tb MINI2440: LCD [0:240x320] 1:800x480 2:1024x768 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off bio: create slab <bio-0> at 0 usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 118 alg: No test for stdrng (krng) io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered Console: switching to colour frame buffer device 60x53 fb0: s3c2410fb frame buffer device s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded at24 0-0050: 1024 byte 24c08 EEPROM (writable) dm9000 Ethernet Driver, V1.31 eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: 08:08:11:18:12:27 (chip) S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns s3c24xx-nand s3c2440-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bi t) Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "u-boot" ftl_cs: FTL header not found. 0x000000040000-0x000000060000 : "u-boot-env" ftl_cs: FTL header not found. 0x000000060000-0x000000560000 : "kernel" ftl_cs: FTL header not found. 0x000000560000-0x000008000000 : "root" ftl_cs: FTL header not found. ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver libusual s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice input: gpio-keys as /devices/platform/gpio-keys/input/input0 s3c2440-ts s3c2440-ts: Starting Created group ts filter len 12 depth 2 close 10 thresh 6 Created Median ts filter len 20 depth 2 dec 24 Created Mean ts filter len 4 depth 2 thresh 65535 Created Linear ts filter depth 2 s3c2440-ts s3c2440-ts: 4 filter(s) initialized s3c2440-ts s3c2440-ts: successfully loaded input: s3c2410 TouchScreen as /devices/virtual/input/input1 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled cpuidle: using governor ladder sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). Registered led device: led1 Registered led device: led2 Registered led device: led3 Registered led device: led4 Registered led device: backlight s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address 0001 mmcblk0: mmc0:0001 E0805 121 MiB mmcblk0: p1 usbcore: registered new interface driver hiddev usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.20. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 128K Populating /dev using udev: done Initializing random number generator... done. Starting network... ip: RTNETLINK answers: File exists
1. Open ./project_build_arm/uclibc/root/etc/inittab file in your buildroot folder; 2. Find next text: #ttyS0::respawn:/sbin/getty -L ttyS0 115200 vt100 # GENERIC_SERIAL 3. Replace it with the text: ttySAC0::respawn:/sbin/getty -L ttySAC0 115200 vt100 # GENERIC_SERIAL 4. Enjoy; 5. Please, please, please (!) read the book "Building Embedded Linux Systems" by Karim Yaghmour (O'Reilly Media).
