libstdc++ problem
themadmax 2010-09-01 00:03:14 Link
Hello
I'm using Emdebian grip on mini2440, and codesourcery g++ compiler on host
computer. When i'm build simple C++ hello world application I've got error:
./hello: /usr/lib/libstdc++.so.6: version `CXXABI_ARM_1.3.3' not found
(required by ./hello)
In host /usr/local/arm/4.3.2/arm-none-linux-gnueabi/libc/usr/lib I have
libstdc++.so.6.0.10.
In mini2440 : /usr/lib/libstdc++.so.6.0.10 so the same version ?
I try to copy from mini2440 /usr/lib/libstdc++.so.6.0.10 to codesourcery
path but I think libstdc++.a is different.
So I try to copy lib from host to mini2440, but I've got 'Illegal
instruction'.
open-nandra 2010-09-01 09:15:25 Link
after looking to surces of emdebian ld.conf.so directory contain 2 files
which point to /usr/local/lib and
/lib/arm-linux-gnueabi;/usr/lib/arm-linux-gnueabi. Could you try ldconfig
or move your libstdc++ to usr/local/lib?
themadmax 2010-09-01 10:39:29 Link
ldconfig command is not present in grip Emdebian.
$cat /etc/ld.so.conf
include /etc/ld.so.conf.d/*.conf
$cat /etc/ld.so.conf.d/*
# Multiarch support
# libc default configuration
/usr/local/lib
I try from host
/usr/local/arm/4.3.2/arm-none-linux-gnueabi/libc/usr/lib/libstdc++.so.6.0.10
to mini2440 /usr/local/lib/libstdc++.so.6.0.10, but in this case I have
'Illegal instruction'.
open-nandra 2010-09-01 10:57:00 Link
Are you sure you link your hello app. against libstdc++ for ARM? Please
post your makefile or command for building. Emdebian has libstdc++
installed in /usr/lib so I suppose you link against host library.
themadmax 2010-09-01 11:39:14 Link
hello.cpp
______________________________________________
#include <iostream>
int main(int argc, char** argv)
        std::cout << "Hello" << std::endl;
        return 0;
$arm-linux-g++ hello.cpp -o hello
$file hello
hello: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked
(uses shared libs), for GNU/Linux 2.6.14, not stripped
Copy hello to mini2440
$ldd hello
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x40026000)
        libm.so.6 => /lib/libm.so.6 (0x40101000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x401ae000)
        libc.so.6 => /lib/libc.so.6 (0x401c2000)
        /lib/ld-linux.so.3 (0x40000000)
open-nandra 2010-09-01 11:46:23 Link
Try to look at: http://www.codesourcery.com/archives/arm-gnu/msg02933.html
Maybee try to build with toolchain provided by emdebian.
themadmax 2010-09-01 12:35:03 Link
I'm so stupid
$ cd /usr/local/arm/4.3.2/
$ find . | grep libstdc++.so.6.0.10
./arm-none-linux-gnueabi/libc/thumb2/usr/lib/libstdc++.so.6.0.10
./arm-none-linux-gnueabi/libc/armv4t/usr/lib/libstdc++.so.6.0.10
./arm-none-linux-gnueabi/libc/usr/lib/libstdc++.so.6.0.10
So I work with
Thanks,
Be I'm insteresting in toolchain provided by emdebian, I'm going to look
some tutorial to use it.
ender 2011-07-04 17:33:38 Link
/opt/maemo/usr/sbin/extundelete: error while loading shared libraries:
libstdc++.so.6: cannot open shared object file: No such file or directory
Reply
Name
eMail (not visible)
Text
Please enter the number 6251
