Serial comunication with screen
unknowN 2010-08-27 19:02:48 Link
Someone know how to compile screen on mini2440?
SCREEN DOWNLOAD - http://ftp.gnu.org/gnu/screen/
Thanks! =D
open-nandra 2010-08-31 13:36:26 Link
If you would like to build it manually first you need to build ncurses and
then build screen. Easiest solution would be try to use buildroot
(http://buildroot.uclibc.org) where package screen is included and you can
simply select it by kernel style menuconfig.
stereo_m 2010-08-31 17:42:51 Link
Probably the easiest way would be to install debian om emdebian on a sd
card and install screen just with "apt-get install screen". But if you need
the default qtopia then that is maybe not the best option..
unknowN 2010-09-01 21:50:16 Link
open-nandra, do u have any tutorial about buildroot to help me to cross
compile gnu-screen?
Reply
Name
eMail (not visible)
Text
Please enter the number 6632
