WINCEROOT is not set or is invalid
SatK 2010-08-25 17:00:35 Link
I build WinCE image successfully after following the build steps after
loading mini2440 BSP and SDK.
However a little later when I tried to load
F:\WINCE600\OSDesigns\Mini2440\Mini2440.sln, the VS5000 gives error:
The global default tree (WINCEROOT) has not been set or is invalid.
When tried to set the same through Tools>Options>Platform Builder for CE>
OS Design and Build 6.0>Default OS build tree (WINCEROOT) as F:\WINCE600,
it gives error:
The specified default build tree "F:\WINCE600" is not valid.
Also tried setting the environment variable as
set _WINCEROOT F:\WINCE600 from command line as well as from
MyComputer>Properties.....
I donot get the project loaded.
Please help how to resolve this. Thanks in advance.
SatK
megabar 2010-09-07 08:10:43 Link
 Set _WINCEROOT lode PB6.0 true path for you.
Reply
Name
eMail (not visible)
Text
Please enter the number 1036
