Hello Everyone,
I have recently bought a M2440 which I am running Android on. I have
compiled the kernel with the necessary configurations to enable NTFS etc
but when I attach an external drive via USB I don't see it in the /dev
directory. When the system boots up I see the following;
scsi 0:0:0:0: Direct-Access Hitachi HTS545032B9A300 PQ: 0 ANSI:
2 CCS
sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors (320073 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda:<7>usb-storage: queuecommand called
sda1
sd 0:0:0:0: [sda] Attached SCSI disk
I think this implies the device is attached as sda1 doesn't it but in the
/dev directory it isn't listed.
if I now go to /proc/scsi I see the following;
device_info scsi usb-storage
/proc/scsi # cat scsi
Attached devices:
Host: scsi0 Channel: 00 Id: 00 Lun: 00
Vendor: Hitachi Model: HTS545032B9A300 Rev:
Type: Direct-Access ANSI SCSI revision: 02
Attached devices:
/proc/scsi # cd us
/proc/scsi # cd usb-storage/
/proc/scsi/usb-storage # ls
0
/proc/scsi/usb-storage # cat 0
Host scsi0: usb-storage
Vendor: Hitachi GST
Product: SimpleDrive mini
Serial Number: 25120100714104CA
Protocol: Transparent SCSI
Transport: Bulk
Quirks:
So it appears to know that my drive is connected but it isn't available. Is
there anyone that can shed some light on what is happening before I go mad?
Thanks in advance :+)
Unable to see external drive
Hello Coburn64, Thanks for getting back to me. I actually managed to find out what the problem was with a little more digging. The sda1 device actually appears in the dev/block directory. When I execute the following command mount /dev/block/sda1 /mnt it works ok and I can use the drive. Hopefully this will be useful to someone else having the same trouble! Thanks again, Dave
