Hi all. I try to include VT6656 Drive to WINCE6. I download drive from http://code.google.com/p/friendlyarm/downloads/list. it can not build. Output View of VS2005 is show. Error: Could not find file 'C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\VNUWLC6. dll' on disk VNUWLC6.dll C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\VNUWLC6.d ll NK SHK Error: failed setting line makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). BLDDEMO: Mini2440 build complete. Mini2440 - 5 error(s), 72 warning(s) I see build file on C:\WINCE600\3rdparty\VNT\VNUWLC6. it show. BUILD: [Thrd:Sequence:Type ] Message BUILD: [00:0000000000:PROGC ] Build started with parameters: BUILD: [00:0000000001:PROGC ] Build started in directory: C:\WINCE600\3rdparty\VNT\VNUWLC6 BUILD: [00:0000000002:PROGC ] Checking for C:\WINCE600\sdk\bin\i386\srccheck.exe. BUILD: [00:0000000003:PROGC ] Running passes WCEFILES0, MIDL, MC, ASN, THUNK, PRECOMPHEADER, COMPILE, LIB, LINK, MANAGEDRESX, MANAGEDMOD, MANAGEDDLL, MANAGEDEXE, MANAGEDWIN for ARM. BUILD: [00:0000000004:PROGC ] Loading database "C:\WINCE600\3rdparty\VNT\VNUWLC6\Build.dat". BUILD: [00:0000000005:PROGC ] Done. BUILD: [00:0000000006:PROGC ] Computing include file dependencies: BUILD: [00:0000000007:PROGC ] Checking for SDK include directory: C:\WINCE600\sdk\CE\inc. BUILD: [00:0000000008:WARNN ] File: C:\WINCE600\3rdparty\VNT\VNUWLC6\PlatformBuilderTempProject.vcproj.NAKORN-F577E0 50.Nakorn.user does not exist (2). BUILD: [00:0000000009:PROGC ] Scan C:\WINCE600\3rdparty\VNT\VNUWLC6\ BUILD: [00:0000000010:PROGC ] Saving C:\WINCE600\3rdparty\VNT\VNUWLC6\Build.dat. BUILD: [00:0000000011:INFO ] Done. BUILD: [00:0000000012:PROG ] ' prelink.bat' BUILD: [00:0000000013:PROG ] ' postlink.bat' BUILD: [01:0000000014:INFO ] BUILD: [01:0000000015:INFO ] C:\WINCE600\3rdparty\VNT\VNUWLC6>rem - copy dll and pdb to flatreleasedir BUILD: [01:0000000016:INFO ] BUILD: [01:0000000017:INFO ] C:\WINCE600\3rdparty\VNT\VNUWLC6>copy Target\ARMV4I\retail\VNUWLC6.* C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release BUILD: [01:0000000018:INFO ] The system cannot find the path specified. BUILD: [01:0000000019:INFO ] BUILD: [01:0000000020:INFO ] C:\WINCE600\3rdparty\VNT\VNUWLC6>copy Target\ARMV4I\retail\VNUWLC6.* C:\WINCE600\OSDesigns\Mini2440\Mini2440\Wince600\Mini2440_ARMV4I\cesysgen\oak\ta rget\ARMV4I\retail BUILD: [01:0000000021:INFO ] The system cannot find the path specified. BUILD: [01:0000000022:ERRORE] postlink.bat failed - rc = 1 BUILD: [00:0000000023:PROGC ] Files Warnings Errors BUILD: [00:0000000024:PROGC ] Midl 0 0 0 BUILD: [00:0000000025:PROGC ] Message 0 0 0 BUILD: [00:0000000026:PROGC ] Precomp Header 0 0 0 BUILD: [00:0000000027:PROGC ] Resource 0 0 0 BUILD: [00:0000000028:PROGC ] MASM 0 0 0 BUILD: [00:0000000029:PROGC ] SHASM 0 0 0 BUILD: [00:0000000030:PROGC ] ARMASM 0 0 0 BUILD: [00:0000000031:PROGC ] MIPSASM 0 0 0 BUILD: [00:0000000032:PROGC ] C++ 0 0 0 BUILD: [00:0000000033:PROGC ] C 0 0 0 BUILD: [00:0000000034:PROGC ] Static Libraries 0 0 0 BUILD: [00:0000000035:PROGC ] Exe's 0 0 0 BUILD: [00:0000000036:PROGC ] Dll's 0 0 0 BUILD: [00:0000000037:PROGC ] Preprocess deffile 0 0 0 BUILD: [00:0000000038:PROGC ] Resx 0 0 0 BUILD: [00:0000000039:PROGC ] CSharp Compile 0 0 0 BUILD: [00:0000000040:PROGC ] Other 0 0 1 BUILD: [00:0000000041:PROGC ] BUILD: [00:0000000042:PROGC ] Total 0 0 1 BUILD: [00:0000000043:PROGC ] BUILD: [00:0000000044:PROGC ] 0 Warnings, 1 Errors BUILD: [00:0000000045:PROGC ] GetSystemTimes (seconds): Idle: 0 Kernel: 0 User: 0 BUILD: [00:0000000046:PROGC ] Elapsed time (seconds): 0 How to solve this problem? Please advice me.
Bulid WINCE6 + VT6656
i think you are using clean sysgen command. Put all the files in "C:\WINCE600\PLATFORM\mini2440\Files" instead of "C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release" and also read carefully the readme file comes with the package.
hi i've got the same problem, can you be more specific? i think that mistake is here copy Target\ARMV4I\retail\VNUWLC6.* what does Target stand for? Andrea
Hi, It shouldnt be about Sysgen or Clean Sysgen. I think, you couldnt integrate VT6656 Driver correctly. If you can explain what you did step by step, i can help you. ->Where do you locate your new folder? ->If you locate it under /WINCE600/Platform/<yourplatform>/Src/Drivers, did you edit DIRS file? Did you edit platform.bib,platform.reg?Did you create a catalog file for it? etc.. Regards, Bugra Aydogar
