Hi Everybody, I get the code from mutzev ( http://www.friendlyarm.net/forum/topic/189?lang=en ), and i managed to generate my executable that i transfer to the mini via activesync. When i execute it, i got the following message from serial port : Exception 'Data Abort' (4): Thread-Id=0448010e(pth=83af8b70), Proc-Id=044700e6(pprc=8270b8c0) 'adc_dlg.exe', VM-active=044700e6(pprc=8270b8c0) 'adc_dlg.exe' PC=000113d8(adc_dlg.exe+0x000013d8) RA=0001146c(adc_dlg.exe+0x0000146c) SP=001aee70, BVA=00330000 Exception 'Raised Exception' (-1): Thread-Id=0448010e(pth=83af8b70), Proc-Id=00400002(pprc=82008308) 'NK.EXE', VM-active=044700e6(pprc=8270b8c0) 'adc_dlg.exe' PC=c003bc10(k.coredll.dll+0x0001bc10) RA=802384c8(kernel.dll+0x000064c8) SP=d344f3b8, BVA=ffffffff What is wrong ? should i have an adc driver like gpio ? is it possible to access every registers in an user application ? should i make a new nk.bin with the exe inside ??? Please could you give me advices ? Fred
ADC... again...
I take example of FriendlyArm "AD-convert.exe" which is able to convert, but seems not to have drivers... BUT, i look that in the platform.bib, the file is set as "NK" ( for me as "kernel" application ). Does it means that if i put my file in the bib file and regenerate nk.bin, it will work ? Is it the principles of kernel/user mode ?????
