I've been through a lot of issues around this nice dev board, but one needs an answer in order to proceed with developing.. Why this board's loosing after every reboot his time clock?.. i mean, i've set hwclock to sys, then to hw rtc but nothing... it keeps loosing data and time , turning any time to 1970.. this is really annoying me and many apps i run. Please, does anyone have a clue to fix this??? Thanks in advance
Nice question...
Maybe your clock battery on the Mini2440 is dead? It is located right next to the pushbuttons, you can take it out and test it with a multimeter. It should be around 3 volts.
I controlled and it gives more than 3 volts.. maybe i'm running wrong commands setting time.. Can you give me your procedure, in order to understand if this is broken or i am simply dumb??? Thanks a lot
This is not good.. what is happening to rtc??? i'm running debian-armel squeeze.. could be this a kernel problem??? Any ideas??
