BOOTING ERROR
Marcio 2010-08-18 22:43:15 Link
My micro2440 wasnīt booting directly, itīs present the above message and
show the vivi menu.
MMU table base address = 0x33DFC000
DIVN_UPLL0
MPLLVal [M:7fh,P:2h,S:1h]
CLKDIVN:5h
| S3C2440A USB Downloader ver R0.03 2004 Jan  |
USB: IN_ENDPOINT:1 OUT_ENDPOINT:3
FORMAT: <ADDR(DATA):4>+<SIZE(n+10):4>+<DATA:n>+<CS:2>
NOTE: Power off/on or press the reset button for 1 sec
      in order to get a valid USB device address.
NAND device: Manufacture ID: 0xec, Chip ID: 0xda (Samsung K9F2G08U0B)
Could not found stored vivi parameters. Use default vivi parameters.
Massimo 2011-01-04 16:54:02 Link
I've the same error .
I changed the NAND with a new one but the problem persist.
Have you got some news ?
Max
Reply
Name
eMail (not visible)
Text
Please enter the number 2725
