No logo picture
Ali Eren 2010-08-17 09:53:43 Link
I have problem with the boot logo picture on my 7" screen. If I load an
image 240x320 it is working. But if I load an image larger for my 7" screen
800x480 pixels. The logo cant seen on boot and dnw gives message No logo
picture.
Thanks.
Errol 2010-08-17 11:17:40 Link
Try this version of nboot:
http://www.friendlyarm.net/forum/topic/478
Also, is the picture you upload a bmp?
Thank you,
Errol
Ali Eren 2010-08-17 13:44:03 Link
I have used two nboot_A70.bin file at the link Errol but still no image.
Off course its a bmp file. I have used 800x480 pixel 16 bit color 187KB bmp
file.
I have follewed these steps on DNW.
[f] Format NAND Flash
[n] Download Nboot for WinCE
[l] Download WinCE boot-logo
after that I open the Mini2440 in normal mode DNW shows a message "no logo
picture"
Thanks in advance
Ali Eren 2010-08-17 14:53:37 Link
DNW program gives this message after downloding winCE boot-logo
Now, Downloading [ADDRESS:30000000h,TOTAL:1152064]
RECEIVED FILE SIZE: 1152064 (562KB/S, 2S)
Downloaded file at 0x30000000, size = 1152054 bytes
Width, Height, BPP is 800 480 24
The picture is bigger than 384k bytes
Thanks in advance.
Errol 2010-08-17 20:10:27 Link
It is rejecting the image. :-)
What happens if you make the image 24 bit color?
Ali Eren 2010-08-18 08:23:28 Link
--Width, Height, BPP is 800 480 24
It was 24 bit color but also I tried at least mono color but nothing was
changed.
How did you loaded the 800x480 image may be the problem my DNW program it
I have download the DNW program from here
"http://www.friendlyarm.net/downloads";
Errol 2010-08-18 10:04:35 Link
In your earlier post you said it is 16bbp
"I have used 800x480 pixel 16 bit color 187KB bmp"
I think something is automatically converting it to 24bbp and messing it
up.
Make sure it is 24bbp.
It complains about size, "The picture is bigger than 384k bytes". But your
picture is only 187KB. So something is going wrong in the converting.
What version of SuperVIVI are you using?
Ali Eren 2010-08-18 11:42:45 Link
SuperVIVI version: ##### FriendlyARM BIOS 2.0 for 2440 #####
800x480, 24 bbp 1.1 MB logo file download result
What else can I check?
Errol 2010-08-18 14:35:54 Link
I will have to go look what my SuperVivi version is.
Now your file is 1.1MB, max logo size for your supervivi is 384KB.
Do you have a menu item "[i] Version"?
If not then you have an old SuperVivi.
Thanks,
Errol
Ali Eren 2010-08-18 16:58:26 Link
There is no menu item "[i]" the all choice are blow.
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[a] Absolute User Application
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[b] Boot the system
[s] Set the boot parameters
[q] Goto shell of vivi
Enter your selection:
Errol 2010-08-18 19:10:32 Link
These are my options. I think you have old SuperVivi and must upgrade it...
[v] Download vivi
[d] Download & Run
[b] Boot the system
[i] Version: 0945-2K
Ali Eren 2010-08-19 09:41:26 Link
I have followed these steps to load SuperVIVI
[f] to format the NAND
[v] to download supervivi
and I selected supervivi-128M file
Now, Downloading [ADDRESS:30000000h,TOTAL:249258]
RECEIVED FILE SIZE:  249258 (243KB/S, 1S)
Downloaded file at 0x30000000, size = 249248 bytes
Found block size = 0x00040000
Erasing...    ... done
Writing...    ... done
Written 249248 bytes
Everything looks ok. But after reset the SuperVIVI menu doesnt change!
if I open the supervivi-128M in notepad I can see the "[i] version" menu.
Thanks.
Andreas Watterott 2010-08-19 09:45:06 Link
You need to update the NOR flash via JTAG. Here is a guide:
http://www.friendlyarm.net/dl.php?file=download.pdf
Ali Eren 2010-08-19 11:47:26 Link
I have followed the same document. The page 10 has the steps below.
6. Press f to format the NAND flash.
7. Press v to download supervivi via USB.
Enter your selection: v
8. Now the bootloader is waiting for data.
Select USB Port -> Transmit and choose the file to send to the board:
supervivi-XXX (XXX = NAND flash size)
Also, I have connected with the JTAG. But this time after LPT port and JTAG
setting H-JTAG was could not detect my device.  And it has given this
message.
"Unable to find target. Please make sure that the hardware is properly
connected and powered up."
Thanks in advance.
Errol 2010-08-19 12:55:26 Link
You must use JTAG. Make sure that you set everything as indicated in the
pictures(if i remember correctly)
Thanks,
Errol
Wim 2010-10-20 08:57:47 Link
I'm very new with the use of linux. Is there a guide to copy a file from my
PC to the /tmp directory of my mini2440?
Thanks,
Wim
Reply
Name
eMail (not visible)
Text
Please enter the number 5671
