Hello When I Bluid OSdesign Project that has problem ,it show "The system cannot find the file Settings\Temp\cebasetst.out." what's problem and how I do? I don't have solution for this.!! Help me,please.
OSdesign problem
this is error detial makeimg for Windows CE (Release) (Built on Jul 10 2006 16:41:09) makeimg: Change directory to C:\WINCE600. makeimg: run command: cmd /C C:\WINCE600\public\common\oak\misc\pbpremakeimg Generating PBWorkspace Custom makeimg build step batch Files to C:\WINCE600\OSDesigns\Mini2440\Mini2440\Wince600\Mini2440_ARMV4I\oak Done Generating PBWorkspace Custom makeimg build step batch Files makeimg: Check for C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\PreMakeIm g.bat to run. makeimg: Found localization settings. makeimg: LOCALE: 0804 LOCALE3: (null) TargetDir: 0804 CodePage=936 LocaleId: 804 PrimaryLandId: 4 SubLangId: 2 makeimg: Building international version for locale 0804 makeimg: Check C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\tokens\08 04\ for tokens. makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0409\ makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0409\cebase.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0409\common.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0409\deviceemulator.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0409\platform.str makeimg: Copy files from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intlfile\ 0409\ to release directory. makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0804\ makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0804\cebase.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0804\common.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0804\deviceemulator.str makeimg: Read string substitutions from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intltrns\ 0804\platform.str makeimg: Copy files from C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\intlfile\ 0804\ to release directory. makeimg: Creating C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\nlscfg.ou t because C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\country.c fg doesn't exist or contains a locale different from 0804. makeimg: run command: fmerge -nls C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\nlscfg.ou t C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ nlscfg.inf fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16) makeimg: run command: fmerge -txt C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ nlssrc.txt C:\WINCE600\public\common\oak\files\locale.txt C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\nlssrc.tx t fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16) makeimg: run command: cenlscmp C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ nlssrc.txt C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\nlscfg.ou t C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\wince.nls NLS data compression utility for Windows CE (Release) (Built on Apr 5 2006 11:33:39) CeNlsCmp: No additional code pages specified. CeNlsCmp: [Reading input file] CeNlsCmp: Parsing locales: CeNlsCmp: Locale: 0804 CeNlsCmp: Will add code page 936 (dec) CeNlsCmp: Locale: 0409 CeNlsCmp: Will add code page 1252 (dec) CeNlsCmp: Will add code page 437 (dec) CeNlsCmp: Parsing calendars: CeNlsCmp: Calendar 0001 CeNlsCmp: Parsing codepage(s): Cenlscmp: Codepage 437Cenlscmp: Codepage 936Cenlscmp: Codepage 1252CeNlsCmp: Parsed code pages. CeNlsCmp: Parsing unicode tables CeNlsCmp: Parsing sortkeys CeNlsCmp: Parsing ideograph exceptions CeNlsCmp: File prc.txt: 20935 rows, 2 columns CeNlsCmp: File prcp.txt: 20935 rows, 2 columns CeNlsCmp: Parsing expansions CeNlsCmp: Parsing exceptions CeNlsCmp: Parsing compressions CeNlsCmp: Parsing jamosorts CeNlsCmp: Parsing case tables CeNlsCmp: Parsing language exception tables CeNlsCmp: [Writing out nls file] CeNlsCmp: Header: 68 bytes CeNlsCmp: Writing out locales CeNlsCmp: Locale 0804: 980 bytes CeNlsCmp: Locale 0409: 1240 bytes CeNlsCmp: Total for all locales: 2220 bytes CeNlsCmp: Writing out calendars CeNlsCmp: Calendar 1: 28 bytes CeNlsCmp: Total for all calendars: 28 bytes CeNlsCmp: Writing out code pages CeNlsCmp: Codepage 437: 2724 bytes CeNlsCmp: Codepage 936: 147644 bytes CeNlsCmp: Codepage 1252: 2300 bytes CeNlsCmp: Total for all codepages: 152668 bytes CeNlsCmp: Writing out unicode tables CeNlsCmp: Header: 48 bytes CeNlsCmp: Ascii digits: 856 CeNlsCmp: Compatibility zone: 2748 CeNlsCmp: Compressions: 4230 CeNlsCmp: Hiragana: 344 CeNlsCmp: Katakana: 344 CeNlsCmp: Halfwidth: 888 CeNlsCmp: Fullwidth: 864 CeNlsCmp: Ctypes: 16520 CeNlsCmp: Total data: 26794 CeNlsCmp: Writing out sort tables CeNlsCmp: Header: 48 bytes CeNlsCmp: SortMap: 86744 CeNlsCmp: Reverse diacritics: 0 CeNlsCmp: Double compressions: 0 CeNlsCmp: SortMap locale exceptions: 0 CeNlsCmp: SortMap ideograph exceptions: 334984 CeNlsCmp: Locale compressions: 0 CeNlsCmp: Uppercase tables: 2220 CeNlsCmp: Lowercase tables: 2196 CeNlsCmp: Expansions: 222 CeNlsCmp: JamoSort Index: 2048 CeNlsCmp: JamoSort Compose: 1120 CeNlsCmp: Default Lang Except uppercase: 52 CeNlsCmp: Default Lang Except lowercase: 32 CeNlsCmp: 0 Lang Except tables: 0 Total data: 429618 CeNlsCmp: Done. Success parsing locale file makeimg: Check for C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\PreFmerge Bib.bat to run. makeimg: run command: fmerge -bib C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\ce.bib C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ config.bib C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ common.bib C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ project.bib C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ platform.bib fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16) makeimg: Check for C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\PostFmerg eBib.bat to run. makeimg: Check for C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\PreFmerge Reg.bat to run. makeimg: run command: fmerge -reg C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\reginit.i ni C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ common.reg C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ project.reg C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\postproc\ platform.reg fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16) makeimg: Check for C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\PostFmerg eReg.bat to run. makeimg: run command: regcomp C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\reginit.i ni C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release regcomp: Got LOCALE=0804, using CodePage=936 regcomp: Error: InitRegistry FAILED on or near line 975 of C:\WINCE600\OSDesigns\Mini2440\Mini2440\RelDir\Mini2440_ARMV4I_Release\reginit.i ni. makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec). makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
