hi all
I'm trying to build a new kernel with buildroot, but I can not make it work
with my mini2440.
I used the following configuration:
Target Architecture
[*] arm
Target Architecture Variant
[*] arm920t
Target ABI:
[*] EABI
Toolchain
[*] Enable RPC // need for NFS support in busybox
[*] Use software floating point // need for for busybox
Package Selection for the target
[*] <choose software you want to use in your system>
Target filesystem options
[ ] tar
[ ] ext2
[*] jffs2
Endianess
[*] little-endian
Flash Type
(x) NAND flash with 2kB Page and 128 kB erasesize
Kernel 2.6.30.2
[*] Linux (Advance Configuration)
Kernel Binary format
[*]zImage
This generates 2 files I zImage file
and a file rootfs.arm.jff2
then attempt to upload the files using mini2440 vivi, doing the following:
[k] Download linux kernel
I upload the file zImage
[y] Download root_yaffs image
I upload the file rootfs.arm.jff2
restart the system
but does absolutely nothing.
can someone help me with this, am I doing wrong?
thanks for helping
Build New Kernel with BuildRoot
Hi martin, 1. Please post here traces you got from console. 2. I think you should try to use these options for kernel: [z] Download zImage into RAM [g] Boot linux from RAM 3. Also you got rootfs in jffs2 format but why did you load it as yaffs? These are just my suppositions as I use u-boot instead of supervivi. Sincerely, Maksim.
hello, thank you very much with the response. I see the problem I use jffs, and should use yaffs. but this generates a new wonder to me as I get the buildroot generates a "rootfs" in yaffs format, since that option I do not have, fires only offers me. (ART, squashfs, jffs2, cramfs, cloop and ext2). how can I resolve this.??? I have another question. I have seen many guides to aid in the menu of supervivi is thus: ##### FriendlyARM BIOS for 2440 ##### [x] bon part 0 320k 2368k [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [c] Download root_cramfs image [a] Absolute User Application [n] Download Nboot [e] Download Eboot [i] Download WinCE NK.nb0 [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [p] Partition for Linux [b] Boot the system [s] Set the boot parameters [t] Print the TOC struct of wince [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi Enter your selection: and mine goes like this: because I do not have these options? my motherboard is an mini2440 128mb ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi Enter your selection: I tried to replace it with u-boot but I was unable, however hard they try always reappears supervivi, I tested with the following two guides: http://narnia.cs.ttu.edu/drupal/node/131 http://crysol.org/es/node/1241 thanks for helping greetings
Hi, Show all you steps for replacing supervivi with u-boot. Post here all console output since supervivi start till 'reset' command in u-boot shell. I can't understand what do you mean "always reappears supervivi". If you scrubbed NAND flash and flashed it with u-boot.bin how supervivi could reappear???
hello thanks for the reply I put the information below.
as really the end of everything, whatever you do reappears "vivi".
[v] Download vivi
[d] Download & Run
[b] Boot the system
Enter your selection: q
Supervivi> load ram 0x31000000 239016 u
Now, Downloading [ADDRESS:31000000h,TOTAL:239026]
RECEIVED FILE SIZE: 239026 (233KB/S, 1S)
Downloaded file at 0x31000000, size = 239016 bytes
Supervivi> go 0x31000000
go to 0x31000000
argument 0 = 0x00000000
argument 1 = 0x000á
U-Boot 1.3.2-dirty-moko12 (Apr 16 2009 - 18:14:52)
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 128 MiB
*** Warning - bad CRC or NAND, using default environment
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
MINI2440 #
MINI2440 # nand info
Device 0: NAND 128MiB 3,3V 8-bit, page size 2048, sector size 128 KiB
MINI2440 #
MINI2440 # version
MINI2440 #
MINI2440 # nand scrub
NAND scrub: device 0 whole chip
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
Erasing at 0x7fe0000 -- 100% complete.
Bad block table not found for chip 0
OK
MINI2440 #
MINI2440 # nand createbbt
Create BBT and erase everything ? <y/N>
Skipping bad block at 0x07f80000
Skipping bad block at 0x07fa0000
Skipping bad block at 0x07fc0000
Skipping bad block at 0x07fe0000
Creating BBT. Please wait ...Bad block table not found for chip 0
Bad block table written to 0x07fe0000, version 0x01
Bad block table written to 0x07fc0000, version 0x01
MINI2440 #
MINI2440 # mtdparts
device nand0 <mini2440-nand>, # parts = 4
#: name size offset mask_flags
0: u-boot 0x00040000 0x00000000 0
1: env 0x00020000 0x00040000 0
2: kernel 0x00500000 0x00060000 0
3: root 0x07aa0000 0x00560000 0
active partition: nand0,0 - (u-boot) 0x00040000 @ 0x00000000
defaults:
mtdids : nand0=mini2440-nand
mtdparts: <NULL>
MINI2440 #
MINI2440 # nand write 0x31000000 u-boot
NAND write: device 0 offset 0x0, size 0x40000
262144 bytes written: OK
MINI2440 #
MINI2440 # reset
[v] Download vivi
[d] Download & Run
[b] Boot the system
hello, I have tried almost everything. previous tests were thus: mini2440 and then turn off the Interuptor "NAND / NOR, NOR in position. and light the mini2440. starts the VIVI, and from there the previous steps. In this way I worked. I tried the same but with the variant: 1. I turn off the mini2440 2. NOR position switch 3. I turn on the mini2440 4. vivi starts, and by the u-boot 5. Interuptor to change the position NAND 6. repeat the above steps. unsuccessfully, whenever I turn the plate in normal position, it appears he lived, and if the start position in NAND, not incidentally, the u-boot, it just is not showing anything greetings
I forget to comment on an important detail, when the mini2440 home for the first time after doing the above steps, I get the following error: U-Boot 1.3.2-dirty-moko12 (Apr 16 2009 - 18:14:52) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: nand_scan(): Cannot allocate oob_buf 0 MiB but only occurred once at the end of the previous steps. and never after as much as the power off and back on, nothing is displayed again. greetings
1. Turn OFF mini2440; 2. 'NOR/NAND' switch in 'NOR' position; 3. Turn ON mini2440; 4. Do all the steps from here http://www.friendlyarm.net/forum/topic/156?lang=en#654; 5. Turn OFF mini2440; 6. 'NOR/NAND' switch in 'NAND' position; 7. Turn On mini2440; 8. If you got "NAND: nand_scan(): Cannot allocate oob_buf" error read next topic http://www.friendlyarm.net/forum/topic/79?lang=en. 9. If you got some other errors - post here all console output.
hi all, I wanted to thank, I got it to work, the u-boot on mini2440 with these steps: 1. load ram 0x32000000 242332 u 2. go 0x32000000 3. nand scrub 4. nand createbbt 5. nand write.e 0x32000000 0x0 0x3b29c 6. dynpart 7. dynenv set u-boot_env 8. saveenv thanks
NAND: nand_scan(): Cannot allocate oob_buf A lot of people have had this problem, but I haven't seen a solution. Here' the list of files that got made. -rw-rw-r-- 1 smead smead 245760 Mar 5 18:46 u-boot-nand16k.bin -rw-rw-r-- 1 smead smead 235520 Mar 5 18:46 u-boot-nand2k.bin -rwxrwxr-x 1 smead smead 234004 Mar 5 18:46 u-boot.bin* I've tried them all with enough RAM allocated, i.e. load ram 0x32000000 250000 u and I still get the problem. Can someone give a real solution? Thanks, Dave.
> NAND: nand_scan(): Cannot allocate oob_buf This is from the "buserror" u-boot (lacking a better label_), you'll see this error if you attempt to run u-boot from RAM. The *very* lazy way to get u-boot on the board is to let Linux boot (the Qtopia image that came with the board) and then use the nandtools to write u-boot into /dev/mtd0 with nandtools, like so # flash_eraseall /dev/mtd0 # nandwrite /dev/mtd0 <u-boot image> Visit http://www.linux-mtd.infradead.org/source.html to get the sources, or you can compile them using buildroot. I compile them from scratch so I can build static binaries, which makes them not dependent on any C library. If you want to build these with build root, search for "flash_eraseall" and you'll see where to enable these. (I seem to recall that you can make a static binary with buildroot) Once u-boot is written into /dev/mtd0, reboot and than do the nand scrub / create bbt routine. This is the approach I've taken, we've re-programmed literally 100's of boards this way with no errors. You can also use supervivi to load the u-boot image directly into flash by writing it directly into flash, by doing the following from the supervivi booloader prompt: load ram 0x0 <size of file> u However, this is less dependable, it seems like the download hangs every once in a while. I have an automated board flashing script, so a dependable repeatable process is paramount. As for the error oob error message, that occurs at the first "malloc" in u-boot. I haven't had the time to trace down why malloc() is failing, I'm guessing that some initialization was skipped and malloc() doesn't have a pointer into the bottom of the heap. But that's just a guess. Regards, gene
Hi Martin i'm also trying to create a zImage with jffs2 rootfs using BUILDROOT. but as i type the make command i get the following error-> "target/u-boot/Makefile.in:272: *** NO U-Boot board name set. Check your BR2_TARGET_UBOOT_BOARDNAME setting. Stop."
Hi, I use mini2440 with 64Mb flash. I get nand_scan(): Cannot allocate oob_buf error, when I try to run u-boot from RAM. I tried all the possibilites but in vain... Is there a U-boot binary which can fix this issue? If so please share me. Thanks in advance, Nandu
https://www.blogger.com/comment.g?blogID=11320970&postID=41189769619... Also, search the bootloader section here.
I want to share my blog to you. there are information about mini2440 and buildroot from my experience. Please go to see it at http://www.evolvelib.com and leave your comments. Thanks
