i've download the tslib and i have installed following this guide. http://projektender.blogspot.com/ i have cross-compiled the qt for arm follow this other guide. http://www.qt-italia.org/tutorials/installazione-qt-462-su-target-arm-sc... now i have a folder called Qt in /usr/local, i think is the qt for arm. i have created an application with qtcreator with Gui I do this: $ cd /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/ $ ln -s /home/stud/apps/tslib_arm/lib/libts-0.0.so.0 libts-0.0.so.0 myProjDir$ ~/apps/qt-everywhere-opensource-src-4.6.3/bin/qmake -project myProjDir$ ~/apps/qt-everywhere-opensource-src-4.6.3/bin/qmake myProjDir$ make ./MyAppName –qws then return the error ./Prova: error while loading shared libraries: libts-0.0.so.0: cannot open shared object file: No such file or directory on the friendlyarm run qtopia 2.2 how can i update to the 4.6? what i have to do now with the /usr/local/Qt folder? Thanks for the reply.
Qt 4.6 installed, and now let's run some application!
i've solved. now the application run, i've found were to put the lib! now i 've another problem if i run myapp -qws the app appear but the touchscreen don't work tslib were crosscompiled before the installation of Qt! what i have to do?!
I suggest that you go to: http://billforums.station51.net/viewtopic.php?f=8&t=15&p=331#p331 and ask Nandy if he would provide you with his arora.sh script or post it. He seems to be handling all the tslib stuff properly. Dave
