Hello, we just got the new Mini6410 with an A70 TS. The problem is that the mouse cursor is jumping all around, about 8mm in each direction while holding on a single spot. Is there a way to avoid that? We already recalibrated the screen, with no success. Furthermore, we'd like to operate the device by finger without the stylus, and that is almost impossible due to the bad screen. It was no problem at all with the 3.5" display. Altough we have really large buttons designed, a finger press is hardly recognized by the touchscreen. Thanks in advance Pec
Mini6410 7" Touchscreen Unresponsive
Maybe a simple test is to disconnect cable from display and board, and reconnect it carefully. Have you controlled setting on option.h (C:\WINCE600\PLATFORM\SMDK6410\SRC\INC)for Define LCD_A70? I'm using the same configuration, mini6410 + lcd A70, without problems.
Max_egodom3, I'm using Tiny6410 module with innolux A70 display. If I change the view angle (not 90 degrees) I can see the white shadow for icon names, and the mouse shadaw also...Do you have the same effect? Thanks in advance.
