hi all, i have a 20 meter cable for sending a 9 byte code,i want to know witch solution have better performance for me? using 9 GPIO pins or using RS232 every 5 meters. thanks a lot;
which is better GPIO or RS232
You only need a RS485 transceiver chip which will be connected to an UART of mini2440. 1-Wire: http://en.wikipedia.org/wiki/1-Wire
If you keep the baud low, and maybe use low capacitance wire, then 20 meters shouldn't be a problem for RS232.
(your code is 9bits or 9 bytes??? anyway is better a serial transmition, not parallel GPIO as you will need some media converter: GPIO 'logic 1' at mini is only 3.3v it's a bad idea to send it 20meters without some kind of trasceiver or buffer... (even i2c is just for lower than 1 meter, just to comunicate 'in-board' not for long distance...) as Errol says, you can use RS232 at lower baudrate...(< 4800 maybe 1200bps) if you need higher baudrate(velocity), consider using RS485. as our mini2440 doesn't have a rs485, you will need a 'rs232 to rs485 converter' (media converter) or consider using a TTL to 485/482 converter (something like the MAX487 but for 3.3V (the MAX487 works for 5VTTL)) don't forget, also ethernet can reach up to 100 meters!! (anybody tested that on an actual mini2440???? i don't have so much cable. but it should work...)
thanks kurenai, i mean 9 bits , and i m using ethernet for connecting to my pc so i must use RS232 or GPIO , thanks again for your guide.
Hi, I would like make a parallel communication with GPIOs. What the max baudrate I will get ? Thanks.
Just a cursory glance at the datasheet . . . PCLK can be run at the same speed as FCLK but I see a max frequency rating of 67MHz. So, if you use 8 ports to shift out one byte that suggests to me 67Mbytes per second. There is some nominal relationship between baud and megabytes per second, that escapes me, at the moment, but I am guessing that you "could" be looking at about 67Mbaud. There is possibly overhead just in writing to the ports of x instruction cycles, which could reduce this by an order of magnitude or ? Still, I think you are looking at some pretty high data rates. If you want a better estimate I could talk to the ARM9 hardware guys at work. What devices do you want to drive in parallel mode? Possibly deserves a new thread, IE <parallel port> or <bit-banging parallel port>
Check this RS232 / RS485 Wiki http://www.rs232-to-rs485.com, its much easier to make a decision if you know the basics.
