Posted - 2009/11/04 : 18:19:59 Hi i am using mini2440, i wanted to use Tplink tl-wn321g+ so i added its DLL file in the BSP "SMDK2440" provided in mini2440 cd after adding registry entries of the DLL file i made the image. The problem is when i load the image for the first time using NOR flash the Tplink works fine but when i reboot it using NAND flash Wince loads fine but TPlink doestn't work.. and if i reboot the system NOR using flash the tplink agian works.. can anybody tell me what am i doing wrong or if i am missing something..?? Thanx in advance...
mini2440 image need help..
Is there appears a WinCE message, when you plug in the adapter? If you got the message (WinCe ask for driver path) - that's a problem whit registry entries. Also, sometimes usb devices didn't start after restart. They need to be removed and reinserted again.
Thanks for your reply.. When i plug the usb device (TPLINK TL-WN321G+) it doesn't ask me for the driver and straight away promt me to establish connection, But this happens only when i load the image using NOR flash.. But second time on reboot using NAND flash it doesn't show any message neither to establish connection nor it ask for the driver even if i reinsert the usb device..
Hi, The problem has been solved, the problem was in the DLL file i was using and some registry errors.. I have found another Driver for wince for Usb Wifi devices on the following link.. http://driverscollection.com/?aid=4001823787533f6a92f52b7ec72 it requires only two files.. RT2501USB.dll and rt2501usb.reg **************** Thanks to Nikolay ******************* if any problem do mail me @: engr_hussain.aftab@hotmail.com engr_hussain.aftab@digitecsystems.com Regards: Hussain Aftab
