I am working with the Mini2440 + 7" LCD. First installed the kernel and root filesystem from download from "Kernel Concepts" and successfully booted Angstrom. Now I downloaded the kernel source along with GCC 4.3.2 and compiled the kernel with the config_mini2440_a70 config file.. All seemed to compile fine but when boot the board it hangs after uncompressing the kernel... below is the boot log.. Any ideas what I may be doing wrong.. Thanks -John G Loading from NAND 64MiB 3,3V 8-bit, offset 0x60000 Image Name: Linux-2.6.29.4-FriendlyARM Created: 2009-06-22 9:33:50 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2022376 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 ## Booting kernel from Legacy Image at 32000000 ... Image Name: Linux-2.6.29.4-FriendlyARM Created: 2009-06-22 9:33:50 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2022376 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... ....................................................... done, booting the kernel.
Help compiling the kernel
Hi, maybe try the configuration used by the the kernel folks and OE: http://cgit.openembedded.net/cgit.cgi/openembedded/plain/recipes/linux/l... If this doesn't work it might be a problem with your bootloader. Greetings Florian
Florian, I tried the OE config recipe but it threw a bunch of errors about "__LINUX_ARM_ARCH__" not defined.... probably because the config is for 2.6.30 and I am trying to compile 2.6.29.. I was thinking even if the config was wrong, there has to be something major to make it not even print out the early boot messages.. or I am missing something basic when I built the kernel... I was unsure of some of the origins of what I had so I started from scratch.. Here is what I did... From http://www.andahammer.com/downloads, I downloaded the friendlyarm2440-package.tar.bz2 package.. Following the instructions from here to reburn uboot, and install the kernel and root file systems http://labs.kernelconcepts.de/Publications/Micro24401/#Micro2440-Instruc... That all worked fine and the kernel booted.. Next I downloaded angstrom-armv4t-linux-gnueabi-toolchain-gpe-20090527.tar.bz2 and installed it in /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/bin Using the linux-2.6.29-mini2440-20090609.tgz download, I untar'ed it into the ~/src/linux, copied config_mini2440_a70 to .config, and edited the Makefile to change the following lines #CROSS_COMPILE = arm-linux- CROSS_COMPILE = arm-angstrom-linux-gnueabi- I added the angstrom tool chain in my path, and ran make uImage everything seemed to compile correctly with the final output having CHK include/linux/compile.h Kernel: arch/arm/boot/Image is ready Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage Image Name: Linux-2.6.29.4-FriendlyARM Created: Tue Jun 30 01:44:41 2009 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2019076 Bytes = 1971.75 kB = 1.93 MB Load Address: 0x30008000 Entry Point: 0x30008000 Image arch/arm/boot/uImage is ready I flashed the kernel by following the instructions on the kernel concepts page again then reset the Mini2440 uBoot came up fine, it found the kernel image and printed what looks like the correct information, verified the checksum, uncompressed the kernel, then just died... Any ideas on what I could be doing wrong.. I am thinking its something big like an Endian issue or maybe mkimage is not doing its job... The build script is picking up mkimage from my Umbuntu 9.0.4 distro from /usr/bin/mkimage Are there any specific version dependencies.. Can you explain how address 0x30008000 is determined to become the boot entry point ? Thank you John Gentilin
the address is from the Makefile.boot used by your kernel arch. If I
remember correctly arch/arm/mach-s3c2410/Makefile.boot in this case.
The address should be correct but you could have set some configuration
options that could cause this effect such as a bad commandline in u-boot or
compiled in or missing serial support.
mkimage from Ubuntu should be fine, I'm using this one too.
This error you got initially is suspicious and migh lead to a broken config
("__LINUX_ARM_ARCH__" not defined....). This sounds like a broken toolachin
or you forgot to set "ARCH=arm" in your make command. You need to do this
for every config target too.
Greetings
Florian
Great idea.. no serial support.. I was thinking that it didn't die, it just went silent.. So I attached the LCD to see if I had a screen and unfortunately no.. it was blank.. Do you have a place where you can post a kernel src image that should just make and load... it would help a lot if I had a reference point to get me started. BTW, I also tried the Linux-2.6.29 (20090609) compiled with the toolchain arm-linux-gcc-4.3.2 with EABI downloaded from this site. and got the same results. I only got the undefined __LINUX_ARM_ARCH__ error when I tried to copy the OE config recipe that you provided a link for in my 2.6.29 tree.. Thank you John Gentilin
Florian, Is it possible that my uboot is compiled with a different tool chain than I am using for my kernel ?? I grabbed the uboot image from the friendlyarm2440-package on the andahammer site.. Which tool chain should I be using.. I currently have 3 GCC 4.3.2 EABI arm-angstrom-linux-gnueabi Code Sourcery 2009 Q1 arm-none-eabi Someone on another blog mentioned that I need to disable the USB drivers.. I tried it but no luck... see http://www.friendlyarm.org/topic.asp?TOPIC_ID=42 Thank you for your time John Gentilin
Hi, that's possible but the toolchain shouldn't matter. I'm using the Angstrom toolchain only. Greetings Florian
k, I will recompile all and try again.. Thank you for all your input.. can you suggest other ways to diagnose this ? Is there a tool to disassemble the uImage files. I could go the crazy route and assembler diff my working image from all the others. Are there any flags I can set to cause a more verbose level of logging.. This is really hard to proceed on where there is no information. How difficult is it to single step with a JTag debugger.. I have a JLink setup.. sounds a little hard code, but maybe I can isolate where the kernel goes south.. Since there are no log messages what so ever, hopefully its early on in the code. One thing I have not tried yet is a get pull from OE, will that kernel have all the drivers to run the LCD, etc.. Thanks again John Gentilin
Success ! I successfully compiled the kernel posted by buserror.. Here are my step by step instructions. Using the tool chain from here http://labs.kernelconcepts.de/downloads/angstrom-armv4t-linux-gnueabi-to... mkdir src; cd src mkdir mini2440; cd mini2440 mkdir uboot; cd uboot git clone git://repo.or.cz/u-boot-openmoko/mini2440.git cd mini2440 make ARCH=arm mini2440_config make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- Replace the bootload using http://labs.kernelconcepts.de/Publications/Micro24401 cd src mkdir kernel; cd kernel git clone git://repo.or.cz/linux-2.6/mini2440.git cd mini2440 make ARCH=arm mrproper make ARCH=arm mini2440_defconfig make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- uImage cp arch/arm/boot/uImage to an sdcard put the sdcard into the mini2440 Replace the kernel using http://labs.kernelconcepts.de/Publications/Micro24401 References http://wiki.linuxmce.org/index.php/Mini2440 http://mini2440.googlecode.com/files/mini2440-bootstrap-v2.sh John Gentilin
I had success with the method laid out in kernelconcepts.de I'm now running their prebuilt version of 2.6.30. However, now my networking doesn't seem to work. I know the HW works since the original 2.6.13 was okay but now I don't even get the little RJ45 lights to flicker when I plug in a working cable. I'm trying to get this whole thing running so I can telnet into the mini2440. Any help available?
I purchased a new board from andahammer.com and now I don't get the hang after "booting the kernel" message. I'm able to load both the pre-built kernel in the download section and load my own zImage built from 2.6.29. Telnet works as well. Someone else bought the first board so I'm not sure where it came from but I know it's a 64MB board. I suspect the supervivi on the NOR flash needs to be upgraded but I'll try that later. I'd rather work on the new board now.
