Hi all! I'm trying to compile different images for Mini2440 as on OpenEmbedded images recipe. At the time only the "console-image" works completely and the "x11-gpe" image builds but XServer doesn't work because it cannot detect the screen. "opie-image" builds but doesn't sense the touchscreen input (but the touchscreen calibration performs correctly). Does anyone has experience to report here? Actually I'm just trying to build a gpe based image. Thanks a lot! Francesco
OpenEmbedded and building images: What works?
I found a - not so nice - solution, that works for me with my gpe image.
In order to make Xfbdev+buildroot work on a mini2440 you have to chnage
hw/kdrive/src/kmode.c and add this modline as the first modline
{ 240, 320, 66, 0,
0, 0, 0, KdSyncNegative,
A vie lines further down, you have to set MONITOR_TIMING_DEFAULT to 0
#define MONITOR_TIMING_DEFAULT 0
The framebuffer does not allow setting of video mode. All ioctl with
FBIOPUT_VSCREENINFO fail. Change lines in
hw/kdrive/fbdev/fbdev.c
/* display it on the LCD **** COMMENT OUT THIS CODE */
/* k = ioctl (priv->fd, FBIOPUT_VSCREENINFO, &priv->var);
if (k < 0)
perror ("1: FBIOPUT_VSCREENINFO");
return FALSE;
... recompile
Frank
Hi I am have the same problem as Francesco for some months without success. Where did you get the board from. Maybe, the LCD type is the issue? I followed the steps at Bill's blog to bitbake and I see a kmode at oetmp/work/armv4t-angstrom-linux-gnueabi/xserver-kdrive-1_1.4.0.90-r5/xorg-serve r-1.4.0.90/hw/kdrive/src/kmode.c Since, these get overwritten everytime we bitbake, how do we modify and bitbake? Thanks in Advance Sunitha
> Since, these get overwritten everytime we bitbake, how do we modify > and bitbake? Well - I don't know too much about bitbake. I'm sure there is a better way, but I leave it to the experts. What I did - I changed kmode.c in oetmp/work/armv4t-angstrom-linux-gnueabi/xserver-kdrive-1_1.4.0.90-r5/xorg-serve r-1.4.0.90/hw/kdrive/src/kmode.c I just deleted kmode.o, lib*.a, ../../../../image/usr/bin/Xfbdev Than - I did bitbake -f -c compile xserver-kdrive bitbake -f -c install xserver-kdrive. .. and I had the new Xfbdev.
by the way - I found this information at http://www.mikrocontroller.net/topic/164843 Sorry, it's in german only.
Modification on framebuffer driver of xorg-server - Question: It's not possible to insert such values on the 'xorg.conf' file instead of digging source code and making modification? Just to preserve the original code as supplied and correctly locate the configuration on the /etc directory... Thanx! Francesco
